Transfer case swap question.
Old Feb 20, 2007 | 04:41 PM
Homelessduck's Avatar
Homelessduck
Hmm... Since this isnt as simple as I had thought, should I opt for a doubler while im at it? Does anyone have a link to doubler kits?
Thanks guys.
Old Feb 20, 2007 | 09:45 PM
MBBFord's Avatar
MBBFord
http://www.offroaddesign.com/catalog/doubler.htm
Not too cheap!
$770 for the adapter, and $190 for the linkage.....
I noticed you said your linkage is messed up on your 203.
That is the worst part of the 203. IF it wouldn't be for the linkage I wouldn't even want to change it out, yes I know it is chain driven, but it is still a pretty good t case.
I got stuck, b/c my linkage was/is messed up and it slipped out of 4wd. I then got pulled out, and started to drive away when the linkage slipped into 4wd causeing my u joint and cv joint to break and when that happened, some how my front driveshaft twisted and bent, and what was left of the driveshafts spun and him my tranny pan, bending it to hell, and causing the ATF to leak out, and it chiped a piece of the transmssion housing, and now the linkage is bent to hell.
I'm going to take that 203 out the first chance I get now.
I too thought about a double, but have change my mind after seeing the cost.
If you have what I said, you should be ok, but as previously mentioned the u joints won't be the same size. Your 75 has 1310 u joints, and the 79 has 1330, and will either require new yokes, or a hybrid u joint. I have used a hybrid u joint before, and it worked pretty good for me.
Old Feb 20, 2007 | 10:03 PM
Homelessduck
Ouch! Terrible story..
$960 for just the kit? Jeez. Its still an option, however im going to try and resolve my linkage issues first.
Thanks guys!
Old Feb 20, 2007 | 10:18 PM
eklock2's Avatar
eklock2
http://www.advanceadapters.com
800-350-2223
Ask for Scott
Old Feb 20, 2007 | 10:47 PM
Homelessduck
Thanks, Ill look into that!
AndysFords
Offroad & 4x4
Jan 28, 2011 04:13 PM
870
Oct 28, 2008 12:10 AM
Flatbed392
Jun 26, 2002 08:34 PM
