Sponsored by: Real Truck
Blinker problem
Old Feb 19, 2007 | 09:50 PM
Therin's Avatar
Therin
Blinker problem
I dont wanna take my truck into ford for this because i know its someting stupid and easy.
About a week ago in my 05 the left blinker just stopped working. It then started to work all of a sudden again, but then after the truck has been running for an hour or so, it refuses to work again.
I know its not the bulbs becuase they wouldnt work period if it was. Anyone know?
Old Feb 19, 2007 | 10:37 PM
BareBones's Avatar
BareBones
The left blinker on my '05 does that too, but so far only when the temperature is below zero...
Old Feb 19, 2007 | 11:27 PM
Monsta's Avatar
Monsta
Sit. Stay.
Low blinker fluid. Pick some more up here.
http://kalecoauto.com/index.php?main...&products_id=6
Barebones, you should get the kind with the special anti-freeze additive.
Old Feb 25, 2007 | 08:48 PM
Therin's Avatar
Therin
ok, its not the cold. its when i turn my headlights on.
is it just a relay you think?
if i leave the lights off or put it to the parking lights its fine, but full lights kills my left blinker.
Old Mar 1, 2007 | 01:29 AM
davhut's Avatar
davhut
Therin, When you say stops working what exactly happens? No lights at all? Light on solid?
Old Mar 1, 2007 | 11:15 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Almost sounds like a bad ground somewhere.
Pretty hard to diagnose over the 'net, but ...
I'd check the ground at the left headlight and maybe the taillight.
Sounds like when the headlight is off (and grounded) the headlight completes the ground. When the headlight is on, suddenly the ground for the signal is gone.
will32_
24
Sep 28, 2014 10:18 PM
93 mix 'n match
New Jersey Chapter
Nov 12, 2011 02:46 PM
wyckedcombo17
Jul 25, 2011 01:23 PM
bbokainen
Mar 30, 2011 08:56 AM
onlya4.9
Oct 30, 2010 03:41 PM
