i was going to just cut it unless it comes out easy. don't realy want to cut unless i have to. been pounded into my head try befor you pry
thanks for the help Kris
ill let you witch way i go
Keith
In the middle of the plug should be a (red?) TPA- Terminal protection assurance. This will pop out with a pick, then you will have access to the pin retainers where you can easily release whatever pin you need to remove. Pop the TPA back in, protect the wire with some tape or Heat Shrink, and you are done.
I added a black slide switch that's inside my overhead storage, It's barely visible and easy to reach.
Take a look at my gallery for pics of how I did it.
Pop
Well Marv, that's enough to put it on my "todo" list. I have a different sytle console, but I think there is enough room to put it in one of the compartments.
Bought the switch at All Electronics, www.allelectronics.com , but I suspect any Rat Shack would have slide switches. Funny thing, when I went to All's website, I didn't find the switch that I bought from them. Maybe it's a "non-catalog" item.
How does the console come down from the headliner? Does it just pop down? It looks like the display is part of the casing and I don't want to damage it. Thanks!!!
