1978 - 1996 Big Bronco
COOLING SYSTEM
Old Oct 22, 2002 | 07:12 AM
paul 123's Avatar
paul 123
COOLING SYSTEM
Hello everybody, I have a problem with my 93 full size bronco, it has a 302 in it, I keep on looseing antifreeze, I had my mechanic do a pressure test and he could not find any leaks, the engine check light keeps coming on, when I check the coolant reservoir it is near empty, anybody had this problem before.
Thanks
Old Oct 22, 2002 | 08:11 AM
georgedavila's Avatar
georgedavila
COOLING SYSTEM
Heater core?
Old Oct 22, 2002 | 10:57 AM
greystreak92's Avatar
greystreak92
COOLING SYSTEM
No external leaks? I hate to ask but what about INternal. If you aren't losing it outside the engine is it leaking inside? Check your oil for grey slimy streaks or sludge. If you discover any at all, chances are you are dealing with a head gasket failure. Hate to be the bearer of bad news but if there are no signs of leakage on the outside of the system, thats the next place to check. Be aware that the grey sludge I'm referring to will be heavier than the oil and usually be the last thing to drip out if there is any in the pan.
Old Oct 24, 2002 | 04:07 PM
paul 123's Avatar
paul 123
COOLING SYSTEM
MANY THANKS FOR THE HELP
Old Oct 25, 2002 | 03:17 PM
JBronco's Avatar
JBronco
COOLING SYSTEM
How much coolant are you losing? Most Broncos lose fluid out of the cap on the coolant recovery tank. It's not a lot at one time, and it dries and you don't see it unless you pop the hood after driving. Over time it makes the level go down. I fixed this by putting some aluminum foil under the coolant recovery tank cap.
Old Oct 25, 2002 | 03:31 PM
pooks's Avatar
pooks
COOLING SYSTEM
Mine used to have a real problem with losing coolant, to the point of almost having none. I replaced the thermostat (the one it had was 180, the new one is 195) and the rad cap, and it hasn't lost any since.
Pooks
1990 Bronco XLT (Casper)
5.8L
Old Oct 26, 2002 | 07:40 AM
paul 123's Avatar
paul 123
COOLING SYSTEM
MANY THANKS FOR THE INFO, THANKS TO YOU ALL i THINK i HAVE A FIX NOW
Old Oct 26, 2002 | 07:41 AM
broncophilly1's Avatar
broncophilly1
COOLING SYSTEM
kg0306
1997 - 2003 F150
13
Mar 15, 2022 07:37 PM
jmykec
Feb 17, 2007 02:49 PM
speedofmouth
Jul 23, 2005 09:31 AM
finster725
1997 - 2003 F150
Sep 1, 2003 08:01 PM
