1978 - 1996 Big Bronco
messed up timing.
Old Oct 23, 2002 | 06:24 PM
bronco351's Avatar
bronco351
messed up timing.
Hey guys I'm going to change my spark plug wires. I was wondering that if after I do this will my timing be messed up Thanks for your help!
Old Oct 23, 2002 | 06:39 PM
edenroadmaster's Avatar
edenroadmaster
messed up timing.
your timing wont change unless you move the whole distributor clockwise or counterclockwise.
edenroadmaster
Old Oct 24, 2002 | 11:11 AM
mrwizard's Avatar
mrwizard
messed up timing.
Just make sure you don't get any of the wires crossed. Easiest way is to remove and replace one wire at a time. That way you make sure they all end up in the right place.
Old Oct 24, 2002 | 10:59 PM
bronco351's Avatar
bronco351
messed up timing.
Thanks guys what brand of wires do you reccomend. I'm going to tackle this project on saturday!
Old Oct 25, 2002 | 08:25 AM
spixican07's Avatar
spixican07
messed up timing.
I use motorcraft spark plugs and wires. I put in some champions once and they went bad after about 4,500 miles, which is rediculous. Motorcraft are the ford recommended ones.
Old Oct 26, 2002 | 08:23 PM
bronco351's Avatar
bronco351
messed up timing.
I decided to go with borg warner. I did it today. only took me 2 ours. I found th eeasiest way to get to the rear passenger plug was from under neath.
Old Oct 27, 2002 | 12:22 AM
spixican07's Avatar
spixican07
messed up timing.
heh yeah that ones a pain. i have yet to get that plug out without breaking it
Old Oct 27, 2002 | 01:19 AM
spixican07's Avatar
spixican07
messed up timing.
jlamb02910
43
Apr 30, 2022 01:56 PM
jimcar-9
Aug 21, 2014 02:18 PM
V8Ranger302
Jul 9, 2010 06:48 AM
southernstyle74
Apr 24, 2004 01:22 PM
kellyb
Feb 14, 2002 11:32 PM
