1978 - 1996 Big Bronco
Bosch Plugs
Old Feb 19, 2007 | 04:16 PM
02fatboy's Avatar
02fatboy
Question Bosch Plugs
hello, I have a 96 bronco W/5.0 and was wondering if anyone out there used Bosch spark plugs on there rigs. If so how they worked, liked or dislike? etc.
Old Feb 19, 2007 | 04:23 PM
buckeyebronco's Avatar
buckeyebronco
I currenty have plain jane Bosch copper plugs gapped to .050 ? and they work well.
Old Feb 19, 2007 | 04:53 PM
Knightwarp's Avatar
Knightwarp
I have Bosch Platinum +2. I get more longevity than just the old fashioned single tang. I spend a little more and yes I think Bosch plugs and premium wires do make a difference.
Old Feb 19, 2007 | 05:47 PM
screwy's Avatar
screwy
I’d strongly recommend motorcraft. I’ve seen Bosch’s fall apart after only 10,000 miles.
Old Feb 19, 2007 | 06:02 PM
alxsnmr's Avatar
alxsnmr
If your engine came with platinums, replace with the same or equivalent. As long as your plugs are the correct heat range for the engine that is all that matters. Heat range means how much heat the plug retains and disapates to the surrounding head. Too hot a plug can cause severe pinging because you have a hot spot in the combustion chamber. I had Bosch Platniums in my bronco when I got it but it was pinging badly before I replaced them with the standard oem motorcraft plugs.
Old Feb 19, 2007 | 11:42 PM
ag30265's Avatar
ag30265
I personaly won't run anything but autolites in my fords, just my preference. I do run bosch in my wifes vw though.
About the +2 and +4- Uhhh fellas, electricity takes the path of least resistance all the time every time. So your not gonna get 2 or 4 sparks from one single point. I can see how they could last a little longer-that if one prong gets gummed or melted the plug would still have fire, but I think it's just a sales ploy, kinda like fram- our package looks better, so we must have a better product
What?
Old Feb 20, 2007 | 06:35 AM
helirich's Avatar
helirich
I think most plugs are the same as far as proformance goes. But Bosch makes the shortest plug. This helps if you are running shorty headers.
Old Feb 21, 2007 | 05:33 PM
02fatboy's Avatar
02fatboy
Thanks a lot for the info and suggestions. Prob. just go with stock, been working fine so far.
Old Aug 8, 2007 | 07:14 PM
dang70's Avatar
dang70
I have ran bosch in everything else and never had problems. however, when I worked at Advance Auto, I heard many say that Bosch and Fords don't go well together, so I use Autolites in mine
Old Aug 9, 2007 | 04:20 AM
Kemicalburns's Avatar
Kemicalburns
also copper is a better conduit for electricity compared to platinum. only benny to platinum plugs is they last longer
Old Aug 9, 2007 | 06:21 AM
jem270's Avatar
jem270
I put bosch in mine 6 years ago and just swapped them out last week with autolites. It runs much better now compared to last week. The bosch lasted a long time for me but I got cheap this time.
