Rubber fuel lines
Old Feb 19, 2007 | 03:39 PM
Tom D's Avatar
Tom D
Rubber fuel lines
Before I start runnung BD through my 93 F250, do I need to change ALL my rubber fuel lines to vitron or is that only on older diesels. If so, I suppose that also means the fuel lines fron the tank, next to the lift pump, and all return lines at the injectors.
Old Feb 19, 2007 | 05:48 PM
fabmandelux's Avatar
fabmandelux
FTE Remembers
Originally Posted by Tom D
Before I start running BD through my 93 F250, do I need to change ALL my rubber fuel lines to vitron or is that only on older diesels. If so, I suppose that also means the fuel lines fron the tank, next to the lift pump, and all return lines at the injectors.
I still haven't gotten a definitive statement from my local Ford dealer on the date that ford changed to synthetic fuel lines, but my son's 1990 7.3 has been running B-80 all winter with no softening of the fuel lines yet. The "90" Dodge Cummins on the ranch has been running B-100, and B-80 for over 3 years with no problems yet also.
I don't think you'll have to change your "93" at all.
Old Mar 5, 2007 | 09:11 PM
AndysFords's Avatar
AndysFords
My 88 doesn't have a rubber line on it, except for where I patched the plastic with rubber, and the return lines, but somewhere it said its ok on return lines b/c they are not under pressure.
