Battery Charge Relay
Old Feb 19, 2007 | 07:55 AM
dzwiss's Avatar
dzwiss
I am the proud owner of a new 07 E-350 6.0 PSD Van with tow package. I have a question re: the battery charge relay. The van cam with the 7 point plug mounted and wired on the rear bumper and a brake control harness which I hooked up to a Prodigy brake controller. The lights on the controller work so I am assuming it is hooked up correctly. The van also came with a FOAB-14B192-A Battery charge relay and instructions to mount it into the jucntion box, which I did. I then started the engine and used a 12V continunity tester and connected it between the center (battery lead) post and the ground on the 7 point connector. No light. Am I missing something, or does it need to be connected to the trailer to work?
Old Feb 19, 2007 | 08:46 AM
jorlee's Avatar
jorlee
You should have tested the top left pin, the center pin is auxialiary/reverse.
http://www.etrailer.com/faq/wiring.aspx
Old Feb 19, 2007 | 09:21 AM
dzwiss's Avatar
dzwiss
Oops
You are right. Thank you. It checks out now.
South Texas, here I come.
jmhoying
May 12, 2013 09:58 PM
Headviking
All Things Towing
May 18, 2012 09:50 PM
putergeek
20
Jun 28, 2009 11:16 AM
blighty
Electrical Systems/Wiring
Jan 5, 2008 08:10 PM
cokeman
Jan 31, 2003 01:18 PM
