240 or 300 ??
Old Feb 22, 2007 | 11:08 AM
chico71f100's Avatar
chico71f100
Smile
i just found a 240 head last night for $30 at the local salvage yard, pulled yesterday. haven't gotten it yet, but it's spoken for.
Old Feb 22, 2007 | 11:28 AM
arctic y block's Avatar
arctic y block
So I can bore the 240 out. And put the rotating assembly from the 300 into it? And use either head? How much do I bore the 240? Are these internally or externally balanced?
Hay it's either this or the GMC Diesel.
Old Feb 22, 2007 | 01:32 PM
scottfreeman's Avatar
scottfreeman
Bore?
240 and 300 have the same bore, only the strokes differ. Cranks and Rods are different throws between the two. So if you swap the 300 internals into the 240 you'll have a 300 w/o overbore. It will have a higher compression ration due to the smaller volume of the 240's head. i recomend this swap, it works great for me.
Old Feb 22, 2007 | 04:09 PM
chico71f100
the engine is internally balanced.
Old Feb 22, 2007 | 04:16 PM
andym's Avatar
andym
If I'm not mistaken, all inline engines are inherently balanced.
Old Feb 22, 2007 | 08:59 PM
arctic y block
Good Thanks guy's. It sounds like the way to go.
6inarowmakeitgo
32
May 5, 2022 09:56 PM
trozei
40
Sep 12, 2020 09:22 PM
kelwar
16
Aug 2, 2015 03:14 PM
fljab
21
Jan 8, 2015 04:58 PM
jim kovaleski
17
Nov 23, 2013 11:01 PM
