Sponsored by: Real Truck
Test drove a '99
Old Feb 18, 2007 | 07:55 PM
scottie2hottie's Avatar
scottie2hottie
Smile Test drove a '99
I'm thinking about buying this '99 SD 5.4 4x4 auto. What should I look out for? Only has 59XXX miles and seems mechanically sound and is powerful(although I'm used to a V6 so......LOL) Thanks in advance guys(and gals)
Old Feb 18, 2007 | 08:10 PM
99f350sd's Avatar
99f350sd
Wow low miles. With that little miles I don't know what to say... Have it checked at a dealer and run an OASIS report at the dealer to see whats been done.
Dick
Old Feb 18, 2007 | 08:11 PM
redford's Avatar
redford
FTE Leadership Emeritus
See if the steering is tight, take it over bumps listen for any strange noises, ask for service records, have a mechanic check it out.
Old Feb 18, 2007 | 08:29 PM
scottie2hottie
any model specific trends? sorry ive never paid too much attn to the superduty forums
Old Feb 19, 2007 | 03:05 PM
Beerstalker's Avatar
Beerstalker
Like they said have a mechanic look it over for any fluid leaks, check the torque on the sparkplugs as they sometimes will come loose and get spit out of the engine ruining the threads. Definitely try out the 4 wheel drive systems as the auto locking hubs are notorious for failing. Other than that you should be pretty set. I had a 99 that I bought in 2001 with 40k on it and put 60k on it in 5 years. The only problems I ever had were with the ESOF 4x4 hubs and solenoid, and I had a slight head gasket leak that I had them fix under warranty. Only reason I got rid of it was someone rearended me and totalled it out.
Old Feb 19, 2007 | 06:19 PM
BigRyanKP's Avatar
BigRyanKP
some things i had go wrong on my 99 was the ball joints and the right front axle shat the bed giving me the death rumble
dunnerjeff
Jan 21, 2015 06:54 AM
gtmustang00
Oct 28, 2009 09:11 AM
RMA
Feb 12, 2008 01:38 PM
truckalpers
1997 - 2003 F150
Oct 20, 2005 09:06 PM
PWRSTRKRED
22
Feb 10, 2004 06:55 PM
