needing some help here
Old Feb 18, 2007 | 03:06 PM
caterpillar's Avatar
caterpillar
Ok so i'm putting the ATS turbo system on and i can't find the fartin smoke screw, only thing i can see in there is the letters "D-2" on the shaft that spins then the rest is dark and hard to see, any help on how to find the fartin thing is greatly appreciated thanks
Old Feb 18, 2007 | 06:27 PM
bilder12's Avatar
bilder12
the screw is inside the trianglular shaped slot on the passenger side of the injection pump. Using a mirror and flashlight, you hand turn the engine over til you see the screw ,, sometimes hard to see, it will come up right in the point of the opening. Probably only need a flat or flat and half. too much is not good.
Old Feb 18, 2007 | 07:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Timing mark on the harmonic balancer needs to be in the 1:00 position.
Use a small mirror and flashlight to see in there.
If you don't see it you are 180 degrees out on the IP, the motor needs rolled over till the timing mark is at 1:00 again.
Two rotations of the crankshaft for one revolution of the IP, so the harmonic balancer makes one complete revolution for 1/2 revolution of the IP.
Old Feb 19, 2007 | 08:57 AM
caterpillar
ok heres a dumb question but i don't know so that is why i ask, but what is the harmonic damper, i looked right behind the fan clutch for a mark but couldn't find anything what am i looking for if anyone has any pictures that would be greatly appreciated/helpful
Old Feb 19, 2007 | 09:14 AM
bilder12's Avatar
bilder12
harmonic balancer is the big thingie on the front end of the crankshaft .. you might know it as the pulley. It has the timing mark ( a groove) on it. that mark should be at about the 1 oclock position when you look at it from the front of the truck to see the fuel delivery screw inside the injection pump. But i find the use of a mirror and flashlight is good. Make sure to use a good allen wrench to adjust the setting becaue it is a tight turning adjustment. You will place the allen wrench toward the back of the engine and pull it forward to increase the fuel delivery. ONLY A FLAT OR FLAT AND HALF !!
Old Feb 19, 2007 | 11:24 AM
Spectramac's Avatar
Spectramac
I'd lean more towards the flat and a half. That's what ATS says in their directions.
wtanner
Nov 3, 2012 07:48 AM
4tl8ford
24
Aug 2, 2011 07:01 AM
great white whaler
1997 - 2003 F150
Nov 17, 2010 02:31 AM
great white whaler
25
Nov 16, 2010 12:35 PM
CounterMaker
Jul 24, 2007 02:56 PM
