95 4.9 issues
Old Nov 1, 2012 | 08:08 AM
wtanner's Avatar
wtanner
95 4.9 issues
Hello, Awesome site here hope someone can chime in and help me!
Anyway my truck is bucking,jerking,fartin, and stalling! It also is bringing up a lean code 172 on koer.
This has been really bothering me. I have replaced distributor bearings worn. Replaced fuel pump and regulator, new air charge sensor, coolant temp sensor, map sensor, removed and cleaned injectors new seals and caps. New tps sensor new egr sensor new vacum lines truck should run new.
Heres where it gets strange!!! If i create a vacum leak to map sensor truck is much more drivable but is now running rich!! Also 2 new map sensors were used with original all the same.
This thing is driving me nuts.
Also to add. New plugs, wires dizzy cap, coil compression on all cylinders well over 150 truck has 165,000 miles new fuel filter to.
Any help would be appreciated thx
Also new oxygen sensor and fuel filter.
Computer was also swapped no change
Old Nov 1, 2012 | 11:19 AM
Truckin Bob's Avatar
Truckin Bob
For a start, I'd clean off the block ground (on the starter) then see what happens.
That single block ground seems to be a "weak point" for the 4.9's.
Dual tanks ????
If so, it could be the in-dash tank selector switch goin' kaput on you.
Bob
Old Nov 2, 2012 | 10:39 PM
wtanner's Avatar
wtanner
Nope, been switched over to single tank, converted the right way.
Checked all grounds nothing there to cause concern.
Just strange if i pull vacum line of tree for map sensor and bend on a downwward angle to create a gap between line and tree truck runs much better.
If i do a koer test like that i get a rich code and it is running rich. Which tells me 02sensor is working and injectors "could" work well enough.
Also if map sensor is plugged in and get truck idleing for a minute, idle will suddenly start to stumble push throttle and it will not take it stumble worse and lose vacum.
If i goose the throttle a few times truck will start to rev and then idle fine for another minute until it suddenly starts to stumble again.
No its not the iac. Its def running lean but why?
Im ready to set fire to this thing and count my loss. Gimme a carb and points and can basicaly fix any problem with a matchbook, paper clip, and vicegrips
Old Nov 3, 2012 | 07:48 AM
serious_lee's Avatar
serious_lee
Might be your computer. I had similar symptoms for the first few minutes of running (although no lean code I don't think) until it reached closed loop mode with the oxygen sensor. I couldn't even start without starter fluid and when it ran it belched rich black smoke. The fuel maps are stored in the ECM and recalled on startup until the oxygen sensor can take over. It's something pretty easy to try, but it will cost you at least $50 for a used one.
*Edit* I just re-read your post... scratch that
vintagequest
Jan 20, 2016 05:02 AM
blood_hound1911
Feb 1, 2008 12:06 AM
dirtybroncoii
Bronco II
51
Mar 26, 2007 09:45 PM
cbslayer
Oct 3, 2006 07:56 PM
forder
Sep 12, 2005 09:58 PM
