Computer Flashes
Old Feb 18, 2007 | 12:19 PM
mmusky1's Avatar
mmusky1
Computer Flashes
I Have 2006 6.0 F350 CC SB SRW
And i Live in Ill. When i ordered it i ordered the heater cord but i could not find it. well 2 weeks ago My truck sat for 3 day With minus -0 temps. And it would not start so i jumped it. Got it running and the engine Icon on the dash came on so i took it in to my dealer so they could check it out and find my heater plug. well they fixed it and and said i did not get the cord. but for $260.00 they would put one on it.As was Driving away and there was a paper on my dash That said .
your Vehicle Received revised engine control software to improve engine operation by cycling the Fuel injectors everytime the eingine is shut off.
The New Soft ware will not reduce engine life, Fuel economy or performance.
Well 700 miles later
around town i use to get between 13 & 14 mpg. Highway 15 - 17.5 mpg
Now im getting Between 8 - 9.5 mpg Around town, And 10.5 to 11.5 Highway
So I took it in they check it out and said there is nothing wrong.
I told them I don't think they had any right to flash it with out my permission
And I wanted it put back the way it was. they can't do that becasue they erasyed the old program.
Well this is my 3rd Power stroke Diesel
I Had 2000 7.3
And a 2003 6.0 that got 17-18 mpg for the first 6 months. then i let them flash it. and i never seen over 14 mpg for the next 2 1/2 years.
I don't know what to do I did'nt ok them to flash my 2006 6.0 they did it anyway with out permission?
Very Frushtrated
Nick N.
Old Feb 18, 2007 | 05:25 PM
F250tuff's Avatar
F250tuff
If you ordered it with the heater cord, then take the paperwork in that shows you ordered/paid for it, and tell them you want it put on the truck.
As far as the mileage goes, there are many other things that could be playing into your calculations. The winter blend of diesel fuel could cause poor mileage as well as the conversion from LSD to ULSD fuel. With the colder weather, air pressure in the tires is more critical as they will have lower pressures while the air is colder. When I took my '06 in for the flash update, I did not see any change in MPG. From what I understand, there were no other major updates in that flash, other than the injector purging.
Old Feb 18, 2007 | 05:53 PM
CanadaGuy's Avatar
CanadaGuy
If you took the truck to the dealer complaining of a cold starting issue and a check engine light that most likely came on due to a misfire, I'd say you did give them permission to do the reflash, since it is a fix for the concerns you brought it in for. I'm sure that once your PCM relearns all of it's operating conditions, you'll get some of your mileage back. And they are right that you can't reflash them back to the old program.
Old Feb 19, 2007 | 11:30 AM
2003 Stroke's Avatar
2003 Stroke
i feel your pain mmusky1.....same thing at my dealer. i had a faulty icp sensor that caused engine light to come on...no problems w/ start-up as it was during the summer. i was getting 18-20 w/ 4" lift and 35's now i'm lucky to get 13.5!! dealer told me they did me a favor and flashed my truck. ha!
i read on this site somewhere to disconnect the batteries and turn the headlights on and this will reset your pcm (or something)...don't waste your time w/ this either - no help. trip to louisville for farm machinery show = 13.7mpg all hwy except for short part. i too want my old truck back!!
Old Feb 19, 2007 | 12:25 PM
vloney's Avatar
vloney
Stroke--- First, get it up to operating temp--disconnect batteries for ten minutes---start, and let idle for five minutes. Disconnecting batteries clears KAM (keep alive memory) Then you perform the turbo/egr valve relearn.
