FE engine upgrade
Old Mar 2, 2007 | 05:35 AM
RTW's Avatar
RTW
FE Engine Upgrade
OK, considering all your inputs heres my plan over the next 6 months. What can I say, married with kids. Check the compression ration of each cylinder. If ok, put a die in my oil to verify the source of my oil leaks. Otherwise rebuild the whole thing. Pull the engine and make the repairs. Install a set of headers with 2 1/2" pipe and flow masters. While everything was out, I will install a Center Force clutch assembly and replace the u-joints and mid bearing. I was also going to install power steering in the process. I just need to find a local shop to shorten my steering column. Once the engine is back in the truck I will convert it to electronic ignition and install a TBI system. What do you guys think about this plan.
thanks,
rtw
Old Mar 2, 2007 | 04:10 PM
George Frasier's Avatar
George Frasier
RTW - Sounds like a plan. We're interested in progress ^dates and finish work. Take pics, if the 'beast' is worth it, to you, it needs it's own scrap book. Happy wrenching.
Old Mar 2, 2007 | 06:41 PM
towmaster's Avatar
towmaster
You will not need to shorten your steering column if you use a Bendix power steering box for a 67-69 model truck.
Old Mar 2, 2007 | 08:37 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
To run a Bendix PS box which is a direct bolt in from a manual box is like adding a hand full of sand into your motor, a POS leaker that's expensive to rebuild and twitchy at speed. Why torture yourself? I yanked my 69K mile Bendix out as it leaked and replaced with a Saginaw system, Bendix is a wall art dust collector now.
Best to change column, left motor perch, firewall bracket, pitman arm off a truck with a more common and cheaper Saginal box, rebuild kits are availabe and cheap. Last time I checked before Ford quit selling Bendix seal kits they wanted $153.
There is a reason why it only lasted a few years and they switched to Saginaw's.
Old Mar 2, 2007 | 09:00 PM
arctic y block's Avatar
arctic y block
Bendix and Garrison. What a night mare.
Old Mar 2, 2007 | 11:58 PM
390cobrajet's Avatar
390cobrajet
check the junk yards, you will be surprised how much interchanges from the trucks and vans of diferent years and body styles. you may be able to find one the right length. 73-79 with power steering have a real short one if memory serves, but best to take a tape measure out in the yard with you. may save some dough and piece of mind when relying on someone elses work. if you want flow, check out glass packs, its a straight shot all the way thru, no curves.
Old Mar 3, 2007 | 03:44 PM
towmaster's Avatar
towmaster
1970-1972 FE powered trucks come with the correct left hand engine perch from the factory regardless if the truck was originally equipped with power steering or not.
Old Mar 3, 2007 | 10:19 PM
"Beemer Nut"
Not so, if you had an early 70 truck (made in 69) that still had a Bendix box you need the Saginaw boxed truck left perch.
Bendix boxed PS truck perch is different than that of a Saginaw PS boxed truck perch.
They are stamped with a different angle between the legs.
Old Mar 5, 2007 | 05:22 PM
George Frasier
While we're on the subject - my '75 F-250 SC doesn't have PS. I'd like to add PS. I have the pump/pulley, and "cooler" pipe. Which steering box is best ? Saginaw, I've been told. What piston / off what ? I can handle it as is, but my other 1/2 wants power. Thanks for D input.
Old Mar 5, 2007 | 08:13 PM
acheda's Avatar
acheda
Before machining exaust manifolds, which I stongly agree is the BEST solution, there is another solution that is cheap & might even work for you. There is a sintered iron version of the soft "donut". I have purchased them at NAPA, but you have to get the parts counter guy to do a little work. (They are probably a FT engine part.) If your surfaces are not too bad, these will "mostly" seal and they will carbon up with time (just like the exhaust manifold-to-head joints without gaskets). Worst case they will leak a little, but will resist blowing out much better than the softies. If your are short of $$$, they are worth a try.
Old May 29, 2007 | 06:03 AM
RTW's Avatar
RTW
Unhappy JR Headers
Ok, I am putting the 1972 F100 back together. I have had several issues but here is one that I am not sure what the solution is. I purchased a set of JR headers. When I installed them, the flange on the header prevents the clutch fork from operation properly. The fork is up against the header flange. I could cut part of the fork to clear the flange but it will still be close. Any suggestions?
Nate1954
Aug 11, 2014 11:37 PM
dspy8083
Oct 14, 2013 10:35 AM
J V
Modular V10 (6.8l)
Jun 12, 2013 08:14 AM
planofootball19
Jan 12, 2012 10:50 PM
magicbus
N. California Chapter
Jul 22, 2006 05:08 PM
