1978 - 1996 Big Bronco
Clogged Heater?
Old Jun 26, 2002 | 10:37 AM
jmackie's Avatar
jmackie
Clogged Heater?
Old Nov 2, 2002 | 05:54 PM
Mudinyureyes's Avatar
Mudinyureyes
Clogged Heater?
I put in an question about my heater. It stopped blowing out hot air not too long ago. You can feel a little bit of heat comming out the vents but it doesnt blow Ford hot anymore. I was told the heater core might be clogged, is there any way I can unclog it or am I looking at putting another one in again.
The heater core i just replaced about a year ago and my turkc doesnt over heat, it seems that the coolent goes in one hose and just doesnt ever come back out I think. ONe hose repains hot after the truck shuts off and the other hose cools down alot faster.
Any help with this situation woulf be great.
~Jason
Old Nov 2, 2002 | 06:57 PM
Mudinyureyes
Clogged Heater?
Oh ya, and one more thing I did. I took one of the heater hoses off after I ran the engine so it warmed up I took off one of the heater hoses and ran the enigine again. Anti freeze flowed out the open end of the heater core slowly and some came out the hose. It seems that its getting a some fluid through there. I dont know. Could i be the water pump not functioning properly? But then again you'd think the truck wouldnt run cool if it did.HELP!!!!
~Jason
Old Nov 3, 2002 | 05:41 AM
1988XLT2002's Avatar
1988XLT2002
Clogged Heater?
open your hood and on the left side of the firewall you'll see the blower motor. i think there are 5 lil screw bolts, take them off and disconnect the wiring harness. Pull the motor off and look inside there for junk like leaves mud etc... I had the same problem kinda, in the summer my AC wasnt blowing hardly at all when cranked all the way. I pull off the motor and looked inside there and found all sorts of crap. You have to look really well though my problem was along the condensor side, but if you find nothing then as mentioned above check you heater core lines etc...
Old Nov 3, 2002 | 10:40 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Clogged Heater?
So, you left the hot hose attached to the core and removed the cool one? And with the truck running at operating temp there was just a little trickle coming out of the core?
If that's the case then I think the core is plugged. Water should flow freely with the truck running. When the core was replaced the last time was the radiator flushed? Generally a core will plug because the trash, rust, scaling, etc. from an old radiator is too much for the core to pass.
Old Nov 3, 2002 | 05:34 PM
steve83's Avatar
steve83
Clogged Heater?
Check the hoses to the core - they CAN collapse internally, but it's rare.
Old Nov 4, 2002 | 12:10 AM
Torky's Avatar
Torky
Clogged Heater?
Here is a quick heater core flow test. Disconnect both hoses at the core tubes. Take a garden hose, no nozzle on it, just the hose end, with the faucet on maybe 1/2 turn. Just hold it up to one of the core tubes by hand. Water should pour pretty fast out of the other tube if its not plugged. Try putting water into the other tube. Should be the same thing.
Old Nov 5, 2002 | 01:19 AM
Mexray's Avatar
Mexray
Clogged Heater?
As I remember when I replaced my leaking heater core last year, the temp control cable hooks to a water valve to regulate the amount of hot water reaching the cores - or how fast it flows -
At any rate, the control cable end just snaps onto the valve, and if it has come loose, or, more likely, the water valve is defective, you won't get a high enough flow to heat things up.
If you do the 'flow test' mentioned above with a garden hose, you should check the water valve also to make sure it's opening all the way 'open'. Pull off the glove box door and check it out.
Old Nov 7, 2002 | 09:37 AM
yosemite's Avatar
yosemite
Clogged Heater?
I just replaced mine and it took 15 minutes at most. 2 hoses and 7 bolts and you are done. If at normal operating temperature the inlet hose is warm and the outlet is not, or is alot cooler, you have a plugged heater core. Both should be about the same temp. Dirty radiator fluid is the probable culprit, so replace the core($16 at Autozone) and flush the radiator out.
Brian
1988 Eddie Bauer 351 EFI
Old Nov 7, 2002 | 01:34 PM
88Dying Bronco's Avatar
88Dying Bronco
Clogged Heater?
>Brian
Ditto here, I just did mine ten minutes ago.Was doing the same thing yours is.problem fixed.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
