2006 F150 Rear Diff
Old Feb 17, 2007 | 01:19 AM
Steemer's Avatar
Steemer
2006 F150 Rear Diff
I got my oil changed at 'Mr. Lube' today. Mr Lube is a Canadian drive-in 'fluid maintenance' service.
The guy in the pit was explaining to me that I should have the oil in my rear differential changed to a heavy guage oil at around 5,000 kms (3100 miles). After that its good for 150,000 kms. My 2006 W14 4x4 has 20,000 kms (12,400 miles).
Truck is going to a Dealer for some work on Monday. I searched through this forum (not the 'net yet) and haven't found anything. What do you guys recommend?
Thanks,
Steem.
Old Feb 17, 2007 | 08:17 AM
kd4crs's Avatar
kd4crs
That guy is just trying to sell you service and oil that you don't need. The diff lube that Ford uses is a high quality synthetic already and it may be better than what he was going to sell you. If you have the traction lok rear differential, you have to add friction modifier to the lube when you change it to allow the clutches to slip properly. You don't need to change it before the interval specified in the owner's manual unless the rear axle is completely submerged in water and the oil may have gotten contaminted by water. Tell the guy at goofy lube to stick to changing motor oil.
Old Feb 18, 2007 | 08:41 AM
Steemer's Avatar
Steemer
"That guy is just trying to sell you service and oil that you don't need."
Don't think so. He was recommending I take it to the Dealer to have it done.
Old Feb 18, 2007 | 10:39 AM
osbornk's Avatar
osbornk
Mr Lube is clueless. I don't know if I would trust them to change my oil. Read the owner's manual.
Old Feb 18, 2007 | 02:18 PM
WhëëlMå1's Avatar
WhëëlMå1
Always follow Ford's recommended service procedures and intervals.
Old Feb 20, 2007 | 02:19 PM
don766's Avatar
don766
The manual states that the rear diff. oil is lifetime unless the axle is submerged in water
Old Feb 20, 2007 | 05:12 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
Like Don said lubed for life if not submerged both diffs are filled with full synthetic gear lube.
Old Feb 20, 2007 | 05:58 PM
ford390gashog's Avatar
ford390gashog
The rear diff already has 75w140 gear lube i can't think of anything thicker. The rear diff is filled for life unless it gets water in it then you need to change it.
Old Feb 21, 2007 | 12:52 PM
KevinM's Avatar
KevinM
Actually the earlier diff had 75-90W, the tsb for the rear whine states to upgrade to 75w-140 synthetic along with the repair.. The 2006 should already have the higher vis oil.
pilotshot
6.4L Power Stroke Diesel
40
Jul 21, 2018 10:30 AM
2006musicman
Jan 5, 2013 04:46 PM
Gage2502
Oil & Lubrication
Feb 25, 2008 04:02 PM
mdpitt
1997 - 2003 F150
Sep 7, 2007 11:02 AM
DAVID'S97F250HD
Dec 17, 2005 11:27 PM
