6.0 heads
Old Feb 16, 2007 | 10:04 PM
Fxehogg1's Avatar
Fxehogg1
6.0 heads
is it possable to get the heads of a 6.0 with out lifting the cab or pulling the engion going to need to install head gaskets ond probably a stud kit to keep compression out of the cooling system and from whistling.
Old Feb 16, 2007 | 10:41 PM
LI PerformanceDiesel's Avatar
you can get them off and on but you can not properly torque the bolts.
Old Feb 16, 2007 | 11:02 PM
6L PWR's Avatar
6L PWR
And if you're going to stud it, then you'll either have to lift the cab or pull the engine. No choice there.
Old Feb 17, 2007 | 02:15 AM
Fxehogg1's Avatar
Fxehogg1
how much do you have to lift the cab do you have to disconnect anything or is there enough slack to lift it just a little or do u have to lift it a lot
