Is this noise normal?
Old Feb 16, 2007 | 07:26 PM
dgeesaman's Avatar
dgeesaman
When I shut down the engine on our 95 F-150 351w, and the hood is up, I usually hear a soft buzz sound that fades away after a few seconds. I hear it coming from the ignitor area.
Is this normal?
Dave
Old Feb 16, 2007 | 07:34 PM
NeXtras's Avatar
NeXtras
I get the same type of sound on my 1994 F-150, seems to come from around where the brake booster is. Now you have me curious, is this normal?
Old Feb 16, 2007 | 08:53 PM
wrenchturner's Avatar
wrenchturner
if my truck ran i'd check and see
Old Feb 16, 2007 | 09:36 PM
str8racing's Avatar
str8racing
my 94 f150 does the same.
Old Feb 16, 2007 | 09:44 PM
69 and 85's Avatar
69 and 85
Everyone - this is not normal, the only thing to do is sell your truck to me fast and cheap!
OK, sorry - I have no idea, but it sounds like it is not a big deal since you all seem to have the same issue.
Old Feb 17, 2007 | 06:45 AM
EPNCSU2006's Avatar
EPNCSU2006
Check your PCV valve. I had one that would buzz.
Old Feb 17, 2007 | 07:30 AM
f22c130's Avatar
f22c130
I've heard it in several vehicles, not just my pickup. I always thought it was just the fuel pump relieving a little bit a pressure, but thats just an idea. I really don't know for sure.
Old Feb 17, 2007 | 08:25 AM
subford's Avatar
subford
Is this normal?
Dave
I do not know what an "ignitor area" is but you will have a sound coming from the backside of the engine compartment on the passenger side as the A/C system equalizes through the metering orifice.
All so the check valves in the brake booster and the vacuum lines going to the vacuum reservoir will make a noise if they are bad.
You have less vacuum on the fuel pressure regulator so it will try to hold more pressure back, not bleed off so this should not make any noise unless it has a hole in its diaphragm or is bad.
You may also hear pressure bleeding pass the rings right after the engine is shut off.
Old Feb 17, 2007 | 08:21 PM
str8racing's Avatar
str8racing
mine comes from the ac area.
Old Feb 17, 2007 | 08:59 PM
jonathandennell's Avatar
jonathandennell
my 94 5.0l does the same thing. seems to come from the solinoid, and when I jiggle around the conector going into it and it goes away. lasts probbably about 8 to 13 seconds.
Old Feb 17, 2007 | 11:53 PM
Skandocious's Avatar
Skandocious
I also have this noise, a very faint whirring/wheezing noise, almost sounds like someone blowing spit bubbles through a straw (sorry for the vulgar description, heh). It seems to be come from near the brake booster. Do I have bad vacuum lines?
-Chris
Old Feb 18, 2007 | 08:09 AM
dgeesaman's Avatar
dgeesaman
Actually I think my noise is coming from the ignition coil. Or something very close by.
Dave
