Offroad & 4x4
York OBA setup
Old Feb 16, 2007 | 06:35 PM
nighthawk285's Avatar
nighthawk285
York OBA setup
Ok, so getting setup to do my OBA buildup with a York compressor. Picked one up at the junkyard today, at least I think that thats what it is, it matched the description, but I don't know the Motorcraft codes, and of all the one's I've seen, I've never seen one with a harmonic balancer-looking thing. Is this what I was looking for?
Old Feb 16, 2007 | 09:32 PM
fishmanndotcom's Avatar
fishmanndotcom
that'll work fine but its not a york. thats a motorcraft. york compressors say York on the tag. slap that badboy on there and ride!
-cutts-
Old Feb 16, 2007 | 09:38 PM
nighthawk285
so the york was the one that said YP on the tag? because that one had a motorcraft tag on it too. People said that these were just yorks that ford used their tag on
Old Feb 16, 2007 | 09:41 PM
fishmanndotcom
yea they are exactly the same design, i dont know if they just used seperate tags or not or if the internals can be swapped around. i do know they will work just fine and know several folks run them hard.
-cutts-
Old Feb 16, 2007 | 09:44 PM
nighthawk285
do these have the same oil problem the yorks do?
Old Feb 16, 2007 | 09:50 PM
fishmanndotcom
oil problems?
-cutts-
Old Feb 16, 2007 | 09:53 PM
nighthawk285
yeah, the problem in that a lot of oil gets into the air system, and you can fix it by plugging one of the holes. Heres a few links.
http://www.rockcrawler.com/techrepor..._mod/index.asp
http://www.jedi.com/obiwan/jeep/york_oilmod.html
Also, none of the other compressors i found had that large harmonic balancer looking thing on it. Is that what it is?
Old Feb 16, 2007 | 09:57 PM
fishmanndotcom
yea it just helps to balance it
i have had no problems with my setup and just run the pump like it is. i know you can buy a coelescing filter setup and put the oil back in the pump but thats a lil pricey
-cutts-
Old Feb 16, 2007 | 10:04 PM
nighthawk285
is the one you have the 210 model? how often do you check your oil in it? sorry for so many questions......do you know how to read the motorcraft tags to find out which york they're equivalent to?
Old Feb 16, 2007 | 10:36 PM
fishmanndotcom
lol its cool man, i dont mind the questions. thats what these message boards are for!
yes york 210
no clue how to decipher the motorcraft tags
i check the oil about once a month or so and usually top it off. however you should know that i have mine laying on its side, that could play a huge factor in the oiling issue
-cutts-
Old Feb 16, 2007 | 10:38 PM
nighthawk285
yeah i noticed that, nice bracket work to adapt to the PSD. do you have the suction tube on the top or on the bottom?
Old Feb 16, 2007 | 10:55 PM
fishmanndotcom
suction on top, output on bottom
i was worried about the oil issue but it hasnt been bad at all!
-cutts-
Old Feb 16, 2007 | 10:59 PM
nighthawk285
is yours on constantly?, or do you only turn it on when you need it?
Old Feb 16, 2007 | 11:30 PM
fishmanndotcom
i have it on a pressure switch but i also have a switch on the dash so if something happens i can cut the power regardless of what the p-switch wants!
-cutts-
Old Feb 16, 2007 | 11:35 PM
nighthawk285
is yours set at 150?
