Oil Dye
Old Feb 16, 2007 | 03:08 PM
hi-jacker's Avatar
hi-jacker
Oil Dye
I put four ounces of Ford oil dye in my PSD 6.0 before taking it in for the tech to look for an oil leak. It will be a couple weeks before I can get it back for repair. Is there any problem with the dye remaining in the oil for an extended period? I wouldn't think so, but thought I'd ask.
Old Feb 16, 2007 | 03:56 PM
CanadaGuy's Avatar
CanadaGuy
Not usually a problem. The only problem that may result is depending on the severity of the leak, that there will be too much dye all over the place it might make it hard to trace where it is coming from. As far as your engine is concerned, it will cause no harm.
PSDNovice
Nov 7, 2014 09:15 PM
DND58
Oct 5, 2012 09:52 PM
jkidd_39
Oct 22, 2009 12:07 AM
mybigredford
Mar 19, 2007 06:41 PM
