97 psd vibration
Old Feb 16, 2007 | 03:03 PM
jake 95psd's Avatar
jake 95psd
97 psd vibration
i have a 97 psd with a vibration in the engine it started around 1600-2000rpms running about 65mph. If I push in the clutch it will go away and then when releasing the clutch it will start vibrating. when it fist started it would not vibrate at an idle but now it does. the clutch does not chatter like a bad dmf. Any chance it might be the harmonic balancer? It has 116,000 miles
thanks Jake
Old Feb 16, 2007 | 03:43 PM
titusf350's Avatar
titusf350
Jake, I am betting that it is the dmf. Mine did the same exact thing. I switched to the smf and did not regret doing it. It is stronger,lessmoving parts,cheaper then a new dmf. Hopefully this will help
Old Feb 17, 2007 | 03:40 PM
dell's Avatar
dell
I have a 96 stroker and a my truck is doing the same thing, but i was wondering what a dmf and a smf are. Any information would help
Old Feb 17, 2007 | 03:42 PM
14psd's Avatar
14psd
Pardon me for my ignorance, but what is the dmf and smf. I have some words that will fill in those letters but I don't think they are the correct ones related to our trucks.
Old Feb 17, 2007 | 06:34 PM
dell's Avatar
dell
Where you asking the same question or were you talking to me
Old Feb 17, 2007 | 07:42 PM
farmert's Avatar
farmert
smf- single mass flywheel
dmf- duel mass flywheel
Old Feb 17, 2007 | 07:47 PM
camdaddy's Avatar
camdaddy
DMF= Dual Mass Flywheel, (Stock)Basically to metal plates connected with springs and rubber. They wear out after time and start to "shake". Mine did and as titusf-350 said, I have replaced mine and have not been more satisfied. I went with the LUK Kit. My repair guy had no problem with it.
SMF = Single Mass Flywheel (aftermarket)
Hope this helps!
Old Feb 18, 2007 | 07:12 PM
dell's Avatar
dell
Thanks for the information. My truck is a 96 and i have never changed the clutch and have never had any problems with it. I am not sure if that is the problem because it feels like a wheel bearing is out but i checked them and they are ok. I recently had the ball joints changed,so i am still lost. If anyone has any info please let me know. thanks
Old Feb 19, 2007 | 07:48 AM
F350_Hauler's Avatar
F350_Hauler
There is a possibility that it is a U-joint. When you're driving along smoothly about 50 miles an hour let off the throttle quickly and wait 2 seconds and re-apply it and wait 5seconds and then let it off again and then reapply it and see if you can feel any clunking. Also see if the vibration disappears when you're accelerating and then comes back when you're driving along at highway speed. You can also jack up the rear and wiggle the tires and see if you can find play in any of the u-joints or the carrier bearing. If it's a wheel bearing sometimes you can really hear it or feel it good in the freezing cold weather(20 degrees-ish). You just drive along slowly at a crawl and the bearing will growl at you. If you go really slow you will hear it sort of rumbling and kind of grinding. It will sound like you're driving over a small-stone driveway or over lots of small little pieces of ice like the size of marbles. It does it best on start up before everything is warmed up. Make sure your tires are aired right up good, too. That will help to make the sounds louder and clearer.
Old Feb 24, 2007 | 10:51 AM
farmert's Avatar
farmert
We found the problem on Jake's 97 psd. It was the dmf. The large bearing in the center of the dmf had come apart allowing the flywheel mass to become off center. A new smf and as good as new. Thanks for the responces.
