HELP...truck quit running!!!
Old Feb 17, 2007 | 12:29 PM
steve81's Avatar
steve81
I just noticed I posted this in the wrong forum....lol....meant to post in the 99-03 7.3L forum.
Old Feb 17, 2007 | 03:15 PM
ForemanES's Avatar
ForemanES
Thats fine the motors are pretty much the same, and this problem is with all 7.3s. Glad to hear your back on the road
Old Feb 19, 2007 | 08:39 PM
Dakota Woman's Avatar
Dakota Woman
My truck quit running!
It's an electrical push-on, pull-off fitting right on top of the pump. Unless things have changed tons between your truck's year & mine, the pump is still belt-driven, so sits at the front of the engine.
See if you can find a copy of Chilton's Motor Manual or similar with good pictures & good instructions. Ask your local reference librarian (those folks are wizards). If it's a "reference" book, as at my library, you can't check it out, so take it to the photocopier & plug in lots of dimes & make copies of whatever you need. Be sure to include their "troubleshooting" section. Then staple them all together & keep it in the pickup in a plastic folder behind or under the seat. Or in the truck's toolbox, if you keep one. If you don't, you should start.
My uncles taught me, "there's no guarantee there will be (a man - we'll say 'a mechanic') around to help you when you need one, so learn to do these things, & always keep a set of tools in the truck. They have been so0o right! All of my boys learned to wash, sew, & cook; all of my girls learned to change oil, plugs, & tires; & it has saved every one of them major inconvenience - & once, a life - sooner or later. There's nuthin' genetic about much of anything past the ability to 'get' children or the ability to 'birth' them; & I have never seen work do itself so someone of the 'wrong' gender wouldn't do it..
I hope this helps..
Old Feb 19, 2007 | 09:36 PM
fishmanndotcom's Avatar
fishmanndotcom
Originally Posted by Dakota Woman
I hope this helps..
huh? lol did you not read anything prior to this post?
-cutts-
Mustangking1
Oklahoma Chapter
Jul 13, 2014 06:47 PM
fearpb
New Member Introductions
Jul 19, 2013 01:08 PM
stromburg
Washington Chapter
Jan 18, 2013 05:58 PM
Steven Walch
6.7L Power Stroke Diesel
Dec 31, 2012 09:17 AM
NorthPac
All Things Towing
24
Jun 27, 2004 07:46 PM
