Chip not working
Old Feb 16, 2007 | 11:57 AM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Chip not working
The other day I was at a light and thought I would hit the high idle to help her warn up faster. Well when I switched it I got nothing, not even any of the other tunes which meant no smoke. I got home unhooked the batts checked the chip, the wire and the switch. All looked ok, so I reinstalled it and it worked. My question is did unhooking the batts or did the chip just slide enough to not make contact any more fix it?
Old Feb 16, 2007 | 01:59 PM
ForemanES's Avatar
ForemanES
Maybe it was just the chip contacts. Usually the truck wont start if the contacts are bad, or it will set a check engine light.
Old Feb 16, 2007 | 03:37 PM
titusf350's Avatar
titusf350
My chip will make mine start with hi idle even when the switch is on 100hp...and some times when you start it the engine lopes like a pulling truck. Is this normal?
glw165
Dec 9, 2014 06:16 AM
ovalhead72
16
Jun 7, 2014 03:53 PM
Country_boy_2007
Dec 25, 2013 01:46 AM
doug84xlt
Jan 30, 2004 03:04 PM
true4.2
Computer Chips & Tuners
Oct 22, 2003 07:56 PM
