Door ding cover up?
Old Feb 15, 2007 | 10:55 PM
OleBlue78F250's Avatar
OleBlue78F250
Door ding cover up?
Ive got a 78 f250 that im restoring and its time for the body work. Luckily the only thing that needs to be done to the body is painting it along with fixin the occasional door dings it has. I was just wonderin how body shops cover up these small dents so they dont show up after it is painted. Thanks.
Old Feb 16, 2007 | 05:38 AM
Indy_Gearhead71's Avatar
Indy_Gearhead71
Depending just how indepth you want to go, and depending on how deep the dings are, there's a couple ways you can go about it. One is to remove the door panel, then use a body hammer on the inside and a dolly on the outside with light taps to bring the metal back as close to where it should be. Then use a light coat of a polyester glazing putty to fill in the remainder of the dent.
The other way ( if the dents are really minor ) would be to use a skim coat of body filler, then sand everything back flush to give your door(s) the like smooth finish they had originally. Rule of thumb, body fillers aren't meant to fill in a big valley or deep dent, they're practical use is up to about an 1/8" maybe just a bit more but nothing major.
I couldn't tell you how many times I've seen something put together only to reveal 1/4" of bondo or better. Not to say this doesn't work, but you run into the issue of cracking, or the filler in time popping out. Good bodywork doesn't have to be the hardest thing in the world, it just takes time and patience.
Old Feb 16, 2007 | 12:43 PM
brucewolff's Avatar
brucewolff
What Indy said is what a body shop would do because your'e paying.
By dings do you mean a chip in the paint, dented metal or both? If it's a chip in the paint and you are not intending to repaint the body panel you can sometimes dab in some color matching paint. If you have dented metal without paint damage youi can get someone to do paintless repair, which is a process whereby they slowly force the dent out from the inside.
Old Feb 17, 2007 | 10:56 AM
Indy_Gearhead71
I thought about the paintless dent repair route too Bruce, but not sure how easy of a time one of those techs would have being his truck is a 78. The thicker and stiffer steel on his truck won't be as easy to work out as one a newer vehicle. I guess he could try that route, but if they don't get it within his personal tolerances, he's still stuck doing some minor bodywork.
Old Feb 17, 2007 | 07:54 PM
bigun72's Avatar
bigun72
Bodywork aint nuttin but a thang !!!
Old Feb 18, 2007 | 09:15 AM
Indy_Gearhead71
True, but why pay a PDR guy, then have to go back and do more bodywork if they can't get it out. I'd rather just save the extra bucks and do it myself from the word go. lol
Gotta agree though, bodywork ain't nothin but a thang.
67highboy
May 21, 2015 09:54 AM
78_f800crewcab4x4
Paint & Bodywork
Apr 21, 2010 07:09 PM
RDC F250 7.3
34
Dec 7, 2007 10:25 AM
mrpaintman
Mar 23, 2007 08:47 PM
ralupien
2004 - 2008 F150
Jul 1, 2004 05:21 PM
