No brakes help???
Old Feb 15, 2007 | 05:51 PM
psimpson's Avatar
psimpson
Question No brakes help???
So here is the deal I have a 1997 f-250 7.3 diesel. I was driving down the road and pulled into a parking lot and I had no brakes!! I looked all over and could not find any brake fluid leaking anywhere. The brake pedal is hard as a rock and the brake light is on. To make matters worse while the truck is idling the power steering pump is making all kind of noise and there is some really black fluid on the front of the driver side valve cover it looks like engine oil. After the truck sits for a minute I have brakes but as soon as I touch the brake pedal it does the same thing!!!! Can somebody please help me??!!! I would greatly appreciate it..!!!
Old Feb 15, 2007 | 06:08 PM
ckal704's Avatar
ckal704
Vacuum pump going? Are you sure it is the power steering pump that is making the noise? Your vacuum pump is in the upper right area of the serpentine belt path.
They do fail eventually, but are not difficult to replace if you have any mechanical ability at all.
Do a search for vacuum pump and you'll find a bunch of info.
Old Feb 15, 2007 | 06:14 PM
psimpson's Avatar
psimpson
Thank you I will google it right now. Anything else let me know.
Old Feb 15, 2007 | 06:28 PM
ckal704's Avatar
ckal704
No...not Google.
Search this site using the search tool.
Try this link for the results of a quick search I did:
https://www.ford-trucks.com/forums/s...earchid=159688
ckal704's Avatar
ckal704
No...not Google.
The threads listed don't all necessarily have to do with replacing the vacuum pump, but I am sure you'll find what you need if you read through what is there.
Old Feb 15, 2007 | 06:35 PM
tjbeggs's Avatar
tjbeggs
your vacum pump is definatly the problem. the black fluid you see is the lube oil from the pump, and the noise is it self destructing. The reason you ahve no brakes is cause the pump provided the needed vacum for the power assist brakes.
Old Feb 15, 2007 | 06:49 PM
Dick7.3's Avatar
Dick7.3
its a simple fix.... three 10mm bolts and you'll need to use the puller/press kit from discount auto. i had to do mine again yesterday. goodthing for the lifetime warranty they give.
Old Feb 15, 2007 | 06:50 PM
ckal704's Avatar
ckal704
It is not hard at all to do this job.
The most difficult part is getting the pulley off the old pump and onto the new pump.
TJBEGGS and I agreed to disagree on appropriate methods of putting the pulley on the new pump.
But I will agree that if you have access to the correct tools, use them. My method was used because it was evening time when I did mine and I had to have it done so I could get to work the next day.
Old Feb 15, 2007 | 08:04 PM
psimpson's Avatar
psimpson
I thank you all for your help!!! This site is unbelievable I have found so much information you all have been so helpfull I think I might try the Hydo pump what do you all think
66styleguy
19
Mar 11, 2017 07:22 PM
RazorsEDGE
May 9, 2016 01:54 PM
erickohl
May 24, 2014 09:56 AM
1930 Dodge
99
Jan 15, 2013 05:09 PM
Fal Grunt
Jul 15, 2008 07:56 PM
