302 Noise - Is this Normal?
Old Feb 15, 2007 | 09:43 AM
mprice's Avatar
mprice
I will admit that I don't have a lot of hands-on experience with big gasoline engines. The last time I worked on a 302 was in my dad's 84 tbird, so my memory is a little rusty.
I now have a 95 Bronco with the 302 and an automatic trans. At any throttle level above idle it makes a continuous put that speeds up with the engine, but doesn't get louder or go away at any RPM. At 1500 it is maybe every .5s. I don't think it is pinging because it doesn't make a gurgling sound that I am used to for that.
Can someone help me figure out what the noise is and if I should worry about it.
Thanks
Old Feb 15, 2007 | 10:25 AM
Kemicalburns's Avatar
Kemicalburns
check for vacum leaks and exhaust leaks. double check your timing with spout connector removed and scan codes.
when was it tuned up last?
Old Feb 16, 2007 | 09:16 AM
mprice's Avatar
mprice
The previous owner had it tuned up in August, but he was a little vague about what he meant by that. I know he had the wires changed, but I don't know about anything else.
I am pretty sure now that it is an exhaust leak. I'll repost when I have a chance to look around.
Rick_Fury
45
Jun 1, 2011 07:03 AM
Rick_Fury
15
Feb 20, 2011 07:43 PM
93F150/302
15
Dec 3, 2007 07:16 PM
BriSan
1978 - 1996 Big Bronco
16
Nov 20, 2002 05:36 PM
brianfulwood
Oct 27, 2002 10:27 AM
