carburator question 300 eng
Ross Pistons 4.060
Hastings Power Flex Rings .060
Federal Mogul Mains .020 Under
Clevite Performance Bearings Std.
Federal Mogul Cam Bearings Std.
Melling Torque Cam
Melling H.V. Oli Pump
Eagle H-beam Rods 6.300 2.100 Rod Journal
Crane Gold Race Roller rockers
ARP Main Stud Kit, Rocker Studs,
Fisher International Ballancer
Bore 4.060
Power Hone 4.060
Mild P&P Intake & Exhaust
Performance valve job
Performance Balance job on Steele Crank w/ in 7 grams
Grind Rod Journals to 2.100
Plumb Intake for Heat via Water Pump
Deck Block to Square
Align hone to Factory specs
Deck block for Zero Deck
Offenhauser C Intake
Holley 1850 600 CFM
S.S. Borla 2 into 2 Header
8' of 3" tubes attached to Flowmaster 40's
195* Thermostat
4 Core Desert Radiator mated w/ the Original Radiator Housing
2 1,200 CPU Electric Fans, on @ 180*, off @ 170* mounted diaginally
MSD 6A Eclectronics Package & Coil
Dura spark II Electronic Ignit
Melling Torque Cam
Bore 4.060
Power Hone 4.060
Holley 1850 600 CFM
195* Thermostat
It depends. What do you mean by radical?
Lots of these engines around with bigger cams and 2v or 4v carbs. Holley 2100 2v's are popular. So are Holley 390, 450, 470, 500, and some 600 cfm's and Demon 525's etc. But, there are no application specific off-the-shelf- performance carbs for modified 300's...takes some tinkering to get everything set up and running together in a satisfactory manner with whatever carb one uses.
