Just wondering if anyone has seen any kit to level the F150 4x4. Just seems like it would look much better if it looked a bit more level. Any suggestions? Would like to get the nose back in the air.
[updated:LAST EDITED ON 23-Dec-02 AT 10:01 PM (EST)]Sorry smoothie...can't help you. But someone will!
I like your truck. I just have to rib you about your poochie lookin' tail lights.
On Edit: Before you guys start giving me negative feedback, let me clarify that this guy is my best friend. I just got him to finally post on here. He has a beautiful Dark Shadow Grey with Silver two-tone Supercrew 4x4, Fx4, Grey Leather, big truck etc...
I drive a '01 F150 Super Cab 4X4. Had the same look. I went under the front and raised it up using the torsion bar adjustments. Put a tape measure on each corner, turned each side the same number of turns, a few at a time. Ended up with about two inches of lift, looks good and level, and then got a front end alignment. Some say an alignment is not needed but mine does drive better after the alignment.
