c6 trans
Old Feb 14, 2007 | 09:18 PM
Shovelhead 93's Avatar
Shovelhead 93
Cool c6 trans
I Have An 86 F150 4x4 5.0,the Trans Is Not Shifting Properly,it Takes Awhile To Shift From First To Second And Wont Shift Into Third Till It Is Around 5o Mph,needs To Build Up Pressure Like It Has A Shift Kit Or Something.it Will Shift Back And Forth Between Second And Third Till I Get A No Load Speed.this All Started After I Put My Foot To The Floor And Let Her Have It,is The Modulater Valve Stuck Or Is It Bigger
Old Feb 15, 2007 | 06:49 AM
cujo8's Avatar
cujo8
I would try replacing the modulator to start with because it is a cheap & easy fix. If it is screw in style I will give you a brand new one (for the price of shipping) that I was sent by mistake when I was rebuilding my C4.
Old Feb 15, 2007 | 07:43 AM
stuart1's Avatar
stuart1
Check for good vacuum at the modulator valve.
Also look at the kd linkage. It could be stuck down.
Old Feb 15, 2007 | 03:32 PM
385seriesHemi's Avatar
385seriesHemi
Try the modulator first but if that does not change the occurances, its rebuild time. As for shifting late you might have low fluid level, bad seals, glogged filter. The fluxuating shifts back n forth I would have to say maybe the shift valve is not working properly. The seals might be going in the rear clutch drum n can only hold up to a certain amount of pressure and then release then engage etc etc.
Old Feb 15, 2007 | 03:48 PM
stuart1's Avatar
stuart1
Ok. I re read your post.
If it started after you put your foot into it you have a valve sticking in the valve body.
Do this.
Remove the kd rod at the carb.
Have an assistant start the vehicle, hold the brake and place the transmission in Drive.
You push down and release the kd rod several times.
This should free the valves up.
Old Feb 15, 2007 | 10:38 PM
Shovelhead 93
Ok so I started it today in neutral and let it warm up for about 8 minutes,I left for work and it was shifting normal again,I will try what you have said in the reply's once it gets warmer,been really cold!!-22 celcious.thax for the input,the truck only has153,000 kilometers on it so it should need a rebuild I hope.
