Keyless entry question
Old Feb 14, 2007 | 07:40 PM
tstewertrules20's Avatar
tstewertrules20
I found the Post in FAQ (or info) about the codes well as i said in the olther post i have a 1998 frod explorer sport
I bought it and the guy tol dme i needed a new Battery ...well i bought one lol and guess what nothing
well i thought i needed a new one so i bought one off ebay
ok my question's
1. can i just put a code in and it work again? if so how do i put a code in (i don't have a manual)
2. if i have to put the new on how do i take the other one off (or can i) or just unhook it
Thanks in advance
Old Feb 14, 2007 | 08:30 PM
JerrySimm's Avatar
JerrySimm
I do not understand your question. Are you asking how to put a personal code into the key pad? You can download a manual for a '98 from here: http://www.genuineservice.com/genuin...ault?page=Home
You'll need to know the factory code to be able to enter your own code. I don't have a clue what you're referring to with regards to take the other one off or unhooking it.
Old Feb 14, 2007 | 08:33 PM
tstewertrules20
WHat i mean is....i just got it and i'm not for sure if my Remote doesn't work or if i need to put the Code back in it (i put a new battery in my remote) But i don't know how to put codes in or where to put them in
if i need to replace the Keyless thing can i unhook it from the car or take it off to put a new one on
Old Feb 14, 2007 | 09:11 PM
JerrySimm's Avatar
JerrySimm
OK, now I see. The code is not in the remote, it's in the car/truck. You program the truck computer to the remote, not the other way around. The remote's code is hard coded into the chip inside. I've got 4 remotes and I've programed both my 2003 and my 2001 explorer to all 4 of them. First suggestion would be to try reprogramming your car to the remote, and if that doesn't work, try reprogramming to another remote.
Old Feb 14, 2007 | 09:14 PM
tstewertrules20
Ok how do i program the car to the remote ?
and this is what i bought on ebay causei thought it was broke..lol will this work for the remote ?
http://cgi.ebay.com/ebaymotors/ws/eB...2131170&rd=1,1
Old Feb 14, 2007 | 09:20 PM
JerrySimm's Avatar
JerrySimm
Download the manual from the site I gave earlier. The procedure is in there. Basically you'll be turning your switch from on to run and back 8 times in less than 5 or 10 seconds. And yes that remote should work. That's the same guy I bought my spares from. I've had good results with him.
Go ahead and download the manual. It doesn't cost, and you'll find it useful in the future.
Old Feb 14, 2007 | 09:46 PM
tstewertrules20
well looking at the Manual i don't have the Number's on my door as it says but i have this on my keyring..LOL
so is this a Keyless remote?
Old Feb 14, 2007 | 10:07 PM
JerrySimm's Avatar
JerrySimm
Not sure what that is. May be an aftermarket keyless. If you don't have the number pad on the drivers door, odds are very high that you also do not have a factory keyless entry, therefore the remote will not work, as it doesn't have the onboard system to work with.
Old Feb 14, 2007 | 10:08 PM
tstewertrules20
Man that's weird ....LOL
Well thanks alot for your help...LOL
