1978 - 1996 Big Bronco
Need advice on a new Cam selection
Old Nov 16, 2002 | 10:06 PM
gvolosh1's Avatar
gvolosh1
Post Need advice on a new Cam selection
Hi!
I have a 1990 Bronco with 302/5.0L EFI engine and stock for AOD transmission.
I need advice for a new cam.
I do NOT do much heavy towing only sometimes my jet ski.
Normally at highway speeds I’m at 2,000 RPM in “overdrive”
When towing I’m at 3,000 RPM in “drive”
I’m really slow on highway passing and want to improve the pick up in this RPM range while still preserving my 12 MPG.
Thank you in advance,
George
gvolosh1@san.rr.com
Old Nov 17, 2002 | 08:55 AM
PigFarmer's Avatar
PigFarmer
gvolosh,
Give CompCams and Crane Cams a call on their tech line. I know they have some good Speed Density cams for your application. Comp recomended the 31-255-5 cam with 114 Deg. Lobe Separation for my '89 F150. This might work well with your Bronco too. Seems to be more of a torque cam and that would probably fit the RPM's that you need to run.
Old Nov 17, 2002 | 11:45 AM
steve83's Avatar
steve83
boingk
Oct 2, 2016 07:48 AM
gingerbreadmaniac
Dec 27, 2013 03:02 PM
Toplait
Jun 8, 2012 08:36 PM
nut behind the wheel
Apr 21, 2009 06:06 PM
gvolosh1
May 2, 2003 09:55 PM
