1978 - 1996 Big Bronco
Keyless Entry Programming
Old Nov 14, 2002 | 06:13 PM
WhiteCobraPilot's Avatar
WhiteCobraPilot
I bought a keyless entry remote on Ebay (it is the right kind, i compared the numbers on the back to my roomates bronco's keyless entry remote) but i cannot figure out how to program it. The instructions that came with it from a Ford manual say to use a jumper wire on the programming connector and then cycle the ignition 8 times, only problem is i cannot find a programming connector on my truck, I looked at my roomates (same thing 1996 Eddie Bauer 351 etc) and didnt see one there either, how do I program the dang thing? I called Texan Ford and the girl in the service department said to cycle the ignition 5times and press a button, did it.. nada.. please help!!
Old Nov 14, 2002 | 08:57 PM
WhiteCobraPilot
after digging around under the dash in the dark, i see a black modul and a gray module behind a blue plastic wrapped thing, there was a connected secured to something with nothing plugged into it, but its way up in there and i could get the cover off, could that be the programming connector?
Old Nov 17, 2002 | 11:21 AM
WhiteCobraPilot
no one can help??
Old Nov 17, 2002 | 11:31 AM
8996EBBroncos's Avatar
8996EBBroncos
Try doing a search. It has been talked about on here before.
Old Nov 17, 2002 | 05:44 PM
WhiteCobraPilot
i searched before posting, but it didnt help. Thanks anyway though.
Old Nov 17, 2002 | 05:46 PM
MadDAWG's Avatar
MadDAWG
