Bronco II Ford Bronco II
back hatch
Old Feb 14, 2007 | 12:48 PM
broncobillyII86's Avatar
broncobillyII86
back hatch
I have a busted plastic sleeve for the back gate, where it hitches onto the door. Can I buy those for my 86 B II and what tool do I need to get the bar off that they come on, it's a star like shape and wear do I but them ...Thanks
Old Feb 15, 2007 | 07:43 AM
kernel-panic's Avatar
kernel-panic
There are only 3 places I know to get these, including the bolts: Dealership, junkyard, and LMC Truck
You can remove the bolts with a Torx bit, I forget which size it is. You can also make the sleeves out of thin-walled pvc in a pinch.
Old Feb 15, 2007 | 10:18 AM
HappyJack's Avatar
HappyJack
Check the "Help" isle at your local auto parts store. My son manages a parts store for a national chain and was able to get these for my 88. He can't remember but I think he was able to get new sleeves. Pretty sure replacement complete assemblies are available also.
Old Feb 15, 2007 | 05:17 PM
fl1a's Avatar
fl1a
The "help" sleeves are available, but the way the striker bolt and washer are put
together, it is very difficult to put them on. They have a perfect match for the
hatch striker bolt, and the auto parts store should also have torx sockets to get
them off and on.
Old Feb 15, 2007 | 10:59 PM
97Centurion's Avatar
97Centurion
Rub my Belly
I got some from Advanced Auto in the Help section. I cut mine so that I could just simply slip them over the post. A year later and they are still on there and holding up fine.
Old Feb 16, 2007 | 11:23 AM
WhiteBroncoII2WD's Avatar
WhiteBroncoII2WD
NAPA may be a good source for help and I know RockAuto.com can supply you with these parts.
Old Jun 8, 2007 | 12:29 AM
tony glenn's Avatar
tony glenn
Take Off Tail Light Assy And You Can Get To The Inside Nut If You Have To Use Some Good Vise Grips Or Pipe Wrench Because They Are Tight Replace With One Fron Rec Yard Leave Just Loosenough So You Can Adjust Quite Simple To Do Just Don't Loose The Inside Nut Tony
