I have just had an engine rebuild on my 97 5.0 for my Mounty. The first time after very little run time I lost oil pressure and pulled it out to find rear thrust bearing damage. I had it rebuilt again and after about 8 miles I lost oil pressure again and see bearing particles in my oil. I initially pulled it for a busted piston, nothing else was wrong. Could I get some input from you guys. Thanks Eric
Welcometo FTE, nice to have you on board.
Here is the link to all the forums here: https://www.ford-trucks.com/forums/index.php
Drop into you local Kentucky Chapter, the Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) and the Explorer, Sport Trac, Mountaineer & Aviator forum.
