Sponsored by: Auxito
rear end noise
Old Feb 14, 2007 | 10:13 AM
MR BIG BUCKS's Avatar
MR BIG BUCKS
rear end noise
I have a 2000 f-150 that just started making noise in the rearend ,pulled cover off and all gears look fine ,pulled axles out ,and bearings look ok,only thing i can find wrong was pitting were outside bearing ride . does anyone know if this would make the grinding noise
Old Feb 14, 2007 | 03:49 PM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome to the forum!
Was it only doing it while turning or did it grind while driving straight?
Old Feb 14, 2007 | 05:32 PM
MR BIG BUCKS
when i would take off , changed bearings,seals and fluid, seems to help some
Old Mar 3, 2007 | 08:54 PM
MR BIG BUCKS
makes noise all the time
Old Mar 3, 2007 | 09:59 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Ya its probably the clutch packs. Both my dads screw and my s cab did it. Most people just say put some ford friction modifyer in it. Normally does the trick. I actually put Royal purple in with some friction modifer and took care of it...
Old Mar 30, 2007 | 01:55 PM
whitecougar's Avatar
whitecougar
could be a bad pinion bearing
