6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
In dash brake controler
Old Feb 14, 2007 | 04:57 AM
kingfish's Avatar
kingfish
Does anyone know if they have upgraded this unit from the 05?
I have a triple axle (6 disc. brake trailer) with elect. over hyd. brakes.
It said in the owners manual of the 05 that the indash would not work, we tried it but it doesn't put out enough power. We ended up putting in a after market control to do the job. My 450 should be in any day, does anyone know if this was updated?
Old Feb 14, 2007 | 07:55 AM
sjprice's Avatar
sjprice
Yes it was, there is a new version that is supposed to handle Elc / Hyd. I think it was used in 06 and later but I am not sure about the date.
Old Feb 14, 2007 | 08:06 AM
Strut61's Avatar
Strut61
Per page #34 on the 08 Super Duty Owners Manual.....
Note: The Ford TowComand integrated trailer brake controller has only been verified to be compatible with trailers having electrically actuated drum brakes (one to four axles) and not hydraullic surge or electric-over hydraullic types.
Old Feb 14, 2007 | 09:03 AM
sjprice's Avatar
sjprice
I stand corrected, I will sit down now.
Old Feb 14, 2007 | 09:15 AM
kingfish's Avatar
kingfish
This is what I don't get... You buy the F450 because it can haul and tow the most, it has larger dia. wheels to handle the larger dia. brakes. One of the best braking systems on the market for heavy loads are elec. or hyd. You can buy ANY after market brake control and they are capable of operating elec./ hyd.
yet you can't use the latest and greatest indash controler from Ford.
I have people ask me all the time why I have an indash control and yet another aftermartket mounted under the dash.
Old Feb 14, 2007 | 09:40 AM
Strut61's Avatar
Strut61
Good question?
Realize the statement is - Has only been "Verified"....Does that mean, it might work, it won't work or you'll find out down the road?
Any Tech's care to decipher the code?
Old Feb 14, 2007 | 11:12 AM
cads03's Avatar
cads03
THERE is someone NOT affraid to man up....I wish more people on the board were like you...
Old Feb 14, 2007 | 11:25 AM
bocomojoe's Avatar
bocomojoe
About a year ago there was an artilcle in 'Trailer Life' about electrlic/hydrolic brakes. It discussed 4 or 5 different manuf. and the compatablity with different brake controllers. The Ford Tow Command was part of the survey. If you go to a library you might find the issure or contact the different axel/brake manuf. for compatablity.
