lights pull button.
Old Feb 13, 2007 | 10:15 PM
Angry Slide's Avatar
Angry Slide
lights pull button.
hello, how do you remove the lights pull button? i've figured out on the others theres a washer type thing that you loosen first then you can pull it from the back. but the light one doesnt seem to remove that way. thank you
Old Feb 13, 2007 | 10:19 PM
jwtimme's Avatar
jwtimme
the headlight switch has a button on the top push it down and pull the rod out. then there is a spanner nut on the frout to take off, the switch should come out the back.
