1978 - 1996 Big Bronco
Help with VIN decode 86 Bronco
Old Feb 13, 2007 | 07:13 PM
smoove_d's Avatar
smoove_d
Please help with decode. Vin is 1FMDU15H8GL817551. Axle code is 16, spring code is VZ, trans code is K. A link to a decoder that works for this year will be appreciated, as will be any other info.
Old Feb 13, 2007 | 09:09 PM
Aciancio's Avatar
Aciancio
ok lets try this [1FM](ford,usa MPV) [D](hydraulic class D brakes) [U15](Bronco) [H8](5.8L/351 V8) [G](1986) [L](michigan plant) [817551](sequence #).
Trans code [K](C6 Auto)
Axle code [16](# 3750 capacity, 3.50 open gears)
spring code [V](font spring # E0TA-5310-VB)
[Z](rear spring # E3TA-5560-ANA)
Now i got these out of a 1985 book but they should be the same
Old Feb 13, 2007 | 09:18 PM
smoove_d's Avatar
smoove_d
Thanks for the info.
