muffler delete question
have any of you done the delete by leaving the system on the truck, and if so was it a pain to fart around under there?
will the noise in the cab be louder?
thanks guys, i may try this mod tommorow, but for some reason i am having second thoughts on it, dont know why.
krenzyryan- how long of a pipe did you use, i have a 3 ft piece, i like how yours lines up really well, it looks like you cut more than just the muffler out, am i right
The stock muffler on the Ford Powerstroke is a VERY restrictive system. If you cannot afford a
brand new 409 Stainless turbo back exhaust system, but you want to reduce backpressure and
lower exhaust temps at the turbo, then the Straight Pipe mod may be for you.
There are a couple of ways of doing this mod. On the 94-97 powerstrokes, the muffler is a straight
through design where the inlet and outlet are "In Line" with each other. Simply cut the old muffler
out and weld a piece of 3.5" aluminized steel pipe in its place.
The 99+ powerstrokes however use an "Offset" muffler. Because of this, you cannot simply weld in a
straight pipe. The way I describe needs minor mechanic skills, a Sawz-All type saw, and a welder.
First, remove the muffler and tailpipe from the truck. Simply under the U-clamp just ahead of the
muffler and work the pipe out of the flange. (This can be more difficult than it sounds if the pipe
is heavily rusted/seized. Remove the exhaust hangars from the rubber grommets and work the tailpipe
out the back of the truck. You may want to jack the Body/frame of the truck up and let the rear axle
weight hang. This will open up a huge amount of room between the axle and body to get the pipe in and out.
Using the Saw-z-All, carefully skin open one side of the muffler to gain access to the inside. Once inside,
cut the two perforated metal tubes out completely. Try to make it a clean cut, and leave youself some
material to weld your new pipe in. Slash-cut your replacement 3.5" pipe so that it fits snugly bewteen
the inlet and outlet of the muffler casing. Tack-weld your straight pipe into place firmly.
Flip the muffler case over and finish skinning the muffler casing off. The reason for only skinning half
the muffler at a time is so that none of the exhaust hangers or tailpipe geometries get messed up. Once
you tack in the new pipe, it will hold everything in place so that you can finish removing the muffler
casing. Final weld your straight pipe on all sides and reinstall opposite of removal. Everything should
line up exactly if you did it right, and your tailpipe should point slightly down or straight out.
You will notice a slightly louder sound level in the cab, but I used a DB meter and it was only a slight
increase. Outside the truck however is a marked increase in sound levels. You will also hear a pronouced
"Turbo Flutter" sound as the exhaust gases pulse across the turbo vanes. Some describe the sound of a
straight piped truck like the sound of a "Big Cam Bigblock motor" when you really romp on the throttle.
