Hello I have a 86 ford 460 it is in a boat.When I got the motor it was all torn down and no crank I don't know if I need a internal or exteral.It has a thin flexplate like for a auto trans and there is 2 coller sleeves for the front of crank one of them is smooth,the other has a fin.Can you tell me what crank I need and what sleeve I need to use??? THANKS DEAD IN THE WATER
Reason: rewrote
Admin posted some great help there. You can also just click on the Forums tab at the upper left in the grey tool bar. Click on Forums and select list to select your forum, when you find it, click on it and select new post to ask your question.
