blower motor problems
Old Dec 27, 2006 | 07:27 PM
downboy's Avatar
downboy
Red face blower motor problems
i have a 1976 ford ranger f250 with a 360 and need a wiring diagram for the blower motor.i replaced the relay thats located under the dash by the glove box.the one i had turned out to be good anywaybut the thing doesn't work still. i went to the wrecking yard to try to get a blower....it turns out i couldn't get the thing off with out pulling off the valve covers too.needless to say the place was closing and i didn't have the time or energy to get er done.does this sound like the right thing to do?help!!!!!
Old Dec 27, 2006 | 07:50 PM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome to FTE!
Sorry to hear about your problem. You will need to post your question in the tech forums since this one is used for introductions. I suggest trying either of these: 1973-1979 F-100 and larger or Electrical Systems/Wiring
There is a lot of information here, be sure and look over the forums to find what you need.
Enjoy the site!
Old Dec 27, 2006 | 08:59 PM
downboy's Avatar
downboy
Question more help
how do i post to the right spot???
Old Dec 27, 2006 | 09:54 PM
Ultramagdan
You can click on the links I typed above or you can browse the forums. Click on the Forums tab at the upper left and it will open up to show all of the forums. Take your time and browse around a bit. When you find the forum you want, click on it and it takes into that discussion. If you want to post a question just click on the blue new topic tab and post it as you did here.
Good luck and if you have questions, just ask!
mcfaddendrafting
New Member Introductions
May 2, 2008 06:17 PM
orecitycraver
Apr 4, 2007 09:24 PM
johnnie21
Mar 22, 2007 04:44 PM
Floydster'sFord
Mar 14, 2007 07:40 PM
johny b
Jan 1, 2007 07:19 PM
