Sub amp installation
Old Feb 13, 2007 | 01:41 PM
cmarzy's Avatar
cmarzy
I Have a 2005 supercrew
Where is the good place to install a mono sub amp
I have a single 10 inch sub under the rear driver seat
I rather not remove the jack
It is @ the installers RIGHT NOW! and they are asking!!!!
HELP!
Thank you in advance
Old Feb 13, 2007 | 01:45 PM
SteveVFX4's Avatar
SteveVFX4
I have a MTX 250 watt mono sub amp, it fit just fine under the passenger front seat.
Old Feb 13, 2007 | 01:52 PM
cmarzy's Avatar
cmarzy
Thank I will let them know
What is the model # so I can check the dimentions and compair
Old Feb 13, 2007 | 02:05 PM
SteveVFX4's Avatar
SteveVFX4
I think it's the MTX Thunder 251D amp. It's pretty small, like 12 inches long by 8 inches wide.
Old Feb 13, 2007 | 02:18 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Mine sits right under the back seat in the middle.
Old Feb 13, 2007 | 02:39 PM
fordtruckman's Avatar
fordtruckman
front passenger seat
Old Feb 13, 2007 | 08:24 PM
blue 2004 FX4's Avatar
blue 2004 FX4
Someone wrote that an amp will fit behind the back seats, I have mine under the passenger seat also but will check out the back seat thing when warmer weather gets here.
Old Feb 14, 2007 | 08:55 AM
STXTEXAS's Avatar
STXTEXAS
I have one under the back seat passenger side and one under the front middle seat compartment. both are alpine.
Old Feb 14, 2007 | 09:03 AM
Field Muzzy 125's Avatar
Field Muzzy 125
Mine is under the front passenger seat.
Old Feb 14, 2007 | 09:48 AM
cmarzy's Avatar
cmarzy
Thanks all
They ended up puting it under the driver seat but it is direcly in front of the rear floor heater duct. It also sticks out behind the seat where my kids feet are going to be. WFT? I think I should have them move it?
Any thoughts?
let me know
Thanks!
Chris
Old Feb 14, 2007 | 09:52 AM
Dozer5's Avatar
Dozer5
You wouldn't think the heat blowing on it would be very good for it. I planned on putting a four channel and a mono behind the rear seat. I checked with my installer and he has done them that way. He said there was plenty of room. No dripping feet on them either.
Old Feb 14, 2007 | 07:29 PM
lethalkustoms's Avatar
lethalkustoms
if you are looking for a place to mount the amp and dont need to get to it on a regular basis there is plenty of room behind the rear seat on the back wall. its a little rough to remove the back rest portion of the seat but is well worth it in the long run. i have my two amps and also xm reciever mounted there. makes a very clean install
cabindoc
6.7L Power Stroke Diesel
Feb 22, 2015 10:36 AM
rat49f6
Jul 30, 2009 11:44 PM
nosfrog
2004 - 2008 F150
Apr 8, 2005 07:34 PM
AWSPYRO
Nov 7, 2003 02:04 PM
