Exhaust Manifold question
Old Feb 13, 2007 | 12:30 PM
nuwave's Avatar
nuwave
Anybody know if EDB 9431 B and EDB 9430 fit on a 292 F-100 4X4. I have dual exhaust now and manifolds are branded with different numbers. The concern is steering column clearance.
Old Feb 13, 2007 | 08:08 PM
airharley's Avatar
airharley
If you wait for a little bit, Number Dummy will have an answer as long as they are truck manifolds. Truck blocks and car blocks are the same as far as I know. As you pointed out it could be a clearance issue since the truck engine bay is different from a car. Do the manifolds you have on now look the same or they totally different?
Old Feb 13, 2007 | 08:27 PM
nuwave's Avatar
nuwave
they look the same. i have located a repro but it is way too much $$$. The only option is stubby headers from reds that are supposed to fit. i have my doubts since the 4X4's have little room between the steering column and firewall.
Old Feb 13, 2007 | 08:36 PM
airharley's Avatar
airharley
I take it they are not in your possesion and don't want to buy them unless you know for sure. That makes sense, I was wondering why you didn't just try them.
