brakes on highboy
Old Feb 13, 2007 | 12:19 PM
Rancho*Ryda's Avatar
Rancho*Ryda
brakes on highboy
hey just wondering what i can do to make my breaks better ive tried bleeding them setting the drums but still it doesn,t stop my truck like it should i have to pump the breaks like 3 times to get my truck to stop ? it,s a 76 highboy with a dana 44 hd disk brake front end. thanks
Old Feb 13, 2007 | 12:47 PM
scottie2hottie's Avatar
scottie2hottie
IN MY EXPERIENCE having to pump it like that is usually the brake booster. You can get a master cylinder and 'break' booster for around $100 bucks for both.
Old Feb 13, 2007 | 11:48 PM
slstreit's Avatar
slstreit
Pumping or "taking another bite", as it were, is just pushing more fluid out there to make things happen. IE: taking up space. (unless the MC is worn out. detectable by fluid on the face of the booster or a fading pedal with steady pressure at a stop) First, check for proper rear adjustment and the rear hardware to make sure the auto-adjusters are not wore out or frozen. IE: "increased space". Next look to the front for obvious problems like the the pad tangs wearing a notch in the caliper/pad hangers, thus preventing free movement. (been there on the latter)
Hope to have helped.
Old Feb 14, 2007 | 12:59 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
IF and its a big IF, everything is bled right and adjusted right maybe your booster is shot or there is something wrong with the proportioning valve. If you need a new booster you might as well upgrade to a 79 F-350 booster.
Old Feb 14, 2007 | 01:07 PM
Mil1ion's Avatar
Mil1ion
Before you start replacing expensive boosters do a booster test.
I say your problem is the master cylinder....a common problem.
