Oil & Lubrication
Transfer case oil
Old Feb 12, 2007 | 10:38 PM
hosenturf's Avatar
hosenturf
Transfer case oil
What types of lube are recomended to use in a transfer case? Are synthetics ok for use with cases over 80k, meaning seal weepage?
Thanks,
Mark
Old Feb 13, 2007 | 02:38 AM
ford390gashog's Avatar
ford390gashog
what kind of T case? what year and model truck?
Old Feb 13, 2007 | 11:03 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE, Mark! Thanks for joining us in the Oil and Lubrication forum.
Old Feb 13, 2007 | 06:43 PM
hosenturf's Avatar
hosenturf
Smile
The owners guide says 'Borg Warner 1356' for a transfer case with a capacitiy of 2 quarts.
The truck is a 1995 F250 460.
Thanks for the welcome Scott.
Old Feb 13, 2007 | 07:40 PM
horsepuller
FTE Emeritus
Hope someone with the same truck or owner's guide can help you out here. I have an older truck with a Borg Warner 1345. It takes Dexron II or Dexron/Mercon ATF. I don't see any problem with synthetic in a transfer case. IMO it's not going to weep any more than conventional lube.
Old Feb 18, 2007 | 04:33 PM
Beast12's Avatar
Beast12
In our plow truck at work I used Synthetic ATF in the transfer case. Every little bit helps.
-Matt
Old Feb 18, 2007 | 08:53 PM
firesoutmatt's Avatar
firesoutmatt
Amsoil ATF works great for Transfercase. Atleast that is what I'm using in mine.
Old Feb 19, 2007 | 08:40 PM
hosenturf's Avatar
hosenturf
Thanks, I'll give the synthetic a shot
Old Feb 20, 2007 | 12:19 PM
Tennesseepowerstroke's Avatar
Mobil 1 synthetic ATF in the Mountaineer.
Old Feb 20, 2007 | 07:54 PM
b2_tim's Avatar
b2_tim
My Borg Warner 1350 uses mercon ATF. 193k miles and going. I do wheel the thing without mercy. Doooo!
Old Feb 21, 2007 | 09:21 AM
jimandmandy's Avatar
jimandmandy
A transfer case is dirt-simple compared to an automatic transmission, or even manual transmission. Heat is not an issue due to no torque converter and there are no sychros. Any ATF will work. Go for it.
Jim
Old Feb 21, 2007 | 09:46 PM
hosenturf's Avatar
hosenturf
I'm going to change the fluid in the tranny with Mobil 1 synthetic ATF. I'll just make sure I get extra for the T-case. I'm guessing this is overkill but, in the words of Carroll Shelby " too much is just enough"
Too bad everything can't be this simple.
Thanks everyone for all the advice and help
Old Feb 24, 2007 | 01:53 PM
deadrx7conv's Avatar
deadrx7conv
If the xcase calls for ATF, then any ATF can be used that meets the spec. Consider the synthetic ATF as an upgrade.
I prefer slightly thicker MTFs/MTLs in x-cases that use ATF. I feel that the mildly thicker fluid, and the AW/EP additive package(some up to GL4 level), will do better to protect the x-case from wear in stressful environments.
High mileage ATFs, racing ATFs, and Synchromesh are also mildly thicker options.
Old Mar 2, 2007 | 09:43 AM
MisterCMK's Avatar
MisterCMK
Make sure that you can get the fill plug out first before draining the t-case
Old Mar 2, 2007 | 10:58 AM
2000Expy's Avatar
2000Expy
Talking
You better not let Bob find out you're using that stuff.
