Jumpin at 45
Old Feb 12, 2007 | 08:22 PM
UGA33's Avatar
UGA33
Jumpin at 45
Have an 06 F-250. At 45mph, the truck starts riding rough, but only at 45 not 44 or 46 only 45. I have 285 70 17 BFG all terrains on it. It did not do this with the stock tires that came on it. The only example i can give is it feels as if the tires have a flat spot on them but they dont. Anyone experienced this?
Old Feb 12, 2007 | 09:18 PM
18vtx00's Avatar
18vtx00
sounds like you have at least one bad tire. bring it to an honest tire store or dealer that has a Hunter road force balancer, this is the only way to find a bent rim, bad tire and if the able to be match mounted, if not then you will be replacing tires.. Make sure they have a competinent Tech doing the work.. It takes alot of time to get the road focing properly if you have to replace bad tires.. Good luck.
