Linkage help
Old Feb 12, 2007 | 08:21 PM
1977graytexan's Avatar
1977graytexan
Linkage help
Okay, mounted headers and clifford intake on the old 300. Now i have a new problem, the linkage. I'm used a motorcraft 2150 and not sure what would be the best direction to mount, and once mounted what should i do about the throttle linkage? any ideas?
Old Feb 13, 2007 | 01:42 PM
63redtudor's Avatar
63redtudor
I have the offy intake which has 2 cast-in holes next to the carb mounting boss. I just tapped them, used a chunk of angle iron to mount the original cable mount (with a little modification) to. Don't know how the clifford is set up, but you might try something like that. I'm also using a 2150 on my 300 & mounted it the same as you would a v8.
Edwin
