Sponsored by: Innova
CB Install and questions
Old Feb 12, 2007 | 02:06 PM
bgblktruk's Avatar
bgblktruk
Hey guys, I'm looking for help with the install of a new Cobra 25WX NW ST in my 2006 F-250 SD.
First a few things I think are pertinent. I live in the city, I will use the CB primarily while out of town and on the highway. I will use it while fishing, hunting (for non hunting and fishing communication) and general off road use, I imagine I will also use it for traffic, food and lodging info while on the road.
The reason I think that information is pertinent is I would like for the entire installation to be easily removable, and if not that anything attached not decrease the clearance on the roof (for parking structures)
Now my questions are...
Should I power this unit with (advantages and disadvantages if you can)
1. A dedicated fused hot wire direct from the battery
2. An existing unoccupied fuse on the stock fuse panel
3. An existing unused upfitter switch
What type of removable connection should I use for the power supply?
What type of antennae is best suited for this situation? Something short for example possibly removable.
Where is yours mounted and how?
Thanks in advance for any help you can offer.
Mike
Old Feb 12, 2007 | 02:33 PM
jyccustoms's Avatar
jyccustoms
on my 06 titan i used a fender mount antena and i pluged the cb into my power point.
the advantige to useing the fendes mount antena is u can use a longer antena for bettes range.
Old Feb 12, 2007 | 02:37 PM
jyccustoms's Avatar
jyccustoms
u can take the antena off the mount and only have the mount lelt on the truck.
Old Feb 12, 2007 | 02:46 PM
bgblktruk's Avatar
bgblktruk
Funny I was going to say, I don't want to mount anything to the body. But felt it better not see what the response was. Now I realize its not even an option for me.
Thank you for your suggestion.
Also I had been using a previous unit plugged into the power point, but I have the phone charger, the iPod radio unit, and the camera charger for the two points as it is now.
Thanks
Old Feb 12, 2007 | 02:51 PM
CobraXP's Avatar
CobraXP
I don't have any real good pictures of the antenna bracket, but you can see in this pic where we have an Antenna mounted on my father's F250:
http://www.cobraxp.com/PagePics/F250/Picture%20089.jpg
My Ranger is the same way. We made a bracket and mounted it to the bed. Then used a mark mount and a quick disconnect on the antenna. That way we can remove the antenna whenever needed by just twisting it. The coax runs from the mark mount in the bed under the truck to the inside at the dash under the carpet.
We have the power plug hard wired to the battery. My setup is the same in my Ranger. Given - we do not remove our CB's, but it would be easy in your case to remove it. Just unplug the power and coax and tuck them either under the seat (if the radio is at the seats) or under the dash (if the radio sits up close to the dash).
If you want to be able to remove everything, then stop at a truck stop and buy a power cord that plugs into the radio and then into the cigarette lighter. Then get a magnet mount antenna. This will not give you the best results, but it will let the entire setup be removable.
Old Feb 12, 2007 | 03:21 PM
bgblktruk's Avatar
bgblktruk
Thanks. I'm looking to compromise my signal sending and receiving capabilities as little as possible.
I like the removable antennae location as it won't effect hauling, tie downs or clearance.
Old Feb 12, 2007 | 09:19 PM
CobraXP's Avatar
CobraXP
What console and seat setup do you have?
Old Feb 13, 2007 | 12:15 AM
bgblktruk's Avatar
bgblktruk
Captains w. center console.
Old Feb 19, 2007 | 07:32 PM
Ervin's Avatar
Ervin
Hi Mike. This might be too late but if you have side pockets in your bed they make cb brackets that go in them. No drilling. You can get a 4' whip and another piece that lets them fold down. Not real easy to take off, but it can be done in about 10 minutes. If the weather clears up I will try to get some pics of mine. As for the power hook up I had to worry about the noise from my alt. I have a 78. Had o use a noise suppressor, and with that any power point worked. Erv
Old Feb 19, 2007 | 08:16 PM
bgblktruk's Avatar
bgblktruk
Great. Thanks for the heads-up. With that bracket are you getting pretty good reception? I wonder about the cab getting in the way of the signal. Thanks again.
Old Feb 19, 2007 | 08:31 PM
Ervin's Avatar
Ervin
Yes I get good reception, but I am running two 4' whips. It talks better out the front, but not to bad to the back. It is going to warm up this week end so I will try to get you some pics. Erv
Old May 3, 2007 | 05:10 PM
bgblktruk's Avatar
bgblktruk
Hey Ervin if you get a chance and can send those pics, I'm looking at this again.
Old May 3, 2007 | 05:41 PM
biga17133's Avatar
biga17133
K-40 has a great ant for twisting off & on,, while still living room to clear any thing can be mounted any were as for power cord dont go with cig lighter it wont give best ground,, in my Rig i just remove cord from bk of C.B,, unplug speaker and twist off ANTeNNaE and go...
Old May 3, 2007 | 06:14 PM
Ervin's Avatar
Ervin
Hi, Mike sure let me charge up the camera, have not used it in a while. Will try to do it this weekend. I will let you know. Erv
Old May 3, 2007 | 07:55 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I use a magnet mount (on the roof) and plug it into the power point or cig lighter. I can talk as far as I can receive....that's all I need.
I do have to watch for low hanging trees tho...dang antenna makes one heck of a racket when it's knocked down!
