E4OD delay catching second gear
Old Feb 11, 2007 | 06:11 PM
boonie's Avatar
boonie
Unhappy E4OD delay catching second gear
Normally I would pick-up second gear at about 15mph.
Well - My engine has to race upwards of 2500 rpms before I catch second...
by then im doing 25-30+ mph.
What can I do to correct....
Change the filter/fluid?
Other sensor gone bad....
adjust the cable?
Need help.... can't afford replace/rebuild at the time.
Thanks.
Old Feb 12, 2007 | 06:51 AM
Randy Pederson's Avatar
Randy Pederson
Check/ change the modulater on the tranny.
Old Feb 12, 2007 | 06:54 AM
Randy Pederson
Sorry to ask the obvious but have you checked the fluid level.
Old Feb 12, 2007 | 07:29 AM
Casey's Avatar
Casey
There is no modulator on an E4OD.
I agree with the fluid. If it's low or burnt it can do this.
Old Feb 12, 2007 | 07:51 AM
arctic y block's Avatar
arctic y block
I was told that the shifting actuator is sticking and a fluid and filter chance can cure it
Jakesexpedition
Dec 17, 2015 08:07 PM
kirbyf
Apr 23, 2015 03:02 PM
Ledgemann
Oct 31, 2014 03:40 PM
nicksorenson
Jul 8, 2014 01:57 PM
Der Bugmeister
Jul 27, 2011 02:08 PM
