remote start or WHAT?
Old Feb 10, 2007 | 10:04 PM
dcsmith's Avatar
dcsmith
Question remote start or WHAT?
I pushed the unlock button on my remote several times in order to make sure the passanger side was unlocked. To my amazement, the truck started. I tried to duplicate that result with no success. I looked in the manual index for "remote start." There is no such subject. I tried it again: pushing the lock botton to make sure it was locked, then the unlock botton several times. The truck started. I pushed the lock button a couple times and the truck turned off. I have tried it again with no result.
Somebody please Help! It was just after I had a new bazooka tube and Ipod interface, speakers and amp installed. I was at circuit city when it happened. I don't know it they triggered it from inside or WHAT. The guys at the auto shop thought I must have a factory or aftermarket system.
I am very confused!
Old Feb 10, 2007 | 10:24 PM
screwy's Avatar
screwy
Well I just tried it on my truck, but nothing happened as I suspected. The procedure for starting is much too complicated to be the result of a short. I would say there has to be a system in place that’s causing this. Did you buy the truck used? I would guess it’s a ford remote start system.
Old Feb 10, 2007 | 10:34 PM
dcsmith's Avatar
dcsmith
remote start
It is a 2005 F150 Lariet. Yes, I did buy it used about 3 weeks ago.
Old Feb 10, 2007 | 11:03 PM
screwy's Avatar
screwy
It would be my guess that you have the ford remote start system installed by the previous owner, I think it’d be unlikely for a different brand to respond to your remote, but not impossible, more likely the ford system, which probably uses very similar frequencies and coding, is responding. Pushing the one button many times may mimic the signal of the start button on its remote, which would be hard to get right every time and is probably why it’s not responding uniformly. I’d take it to the dealer and tell them you think you have the remote start and ask them to check for it. Unfortunately I don’t know much about these systems so I can’t tell you how to check for it.
Old Feb 11, 2007 | 12:45 AM
johnshiredman's Avatar
johnshiredman
Why not just ask the person who previously owned the truck?
Old Feb 11, 2007 | 07:18 AM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Or even just ask the dealer how they operate and try that.
Old Feb 11, 2007 | 08:55 AM
dcsmith's Avatar
dcsmith
Try as I may, it has not done it again since last night.
Old Feb 11, 2007 | 10:09 AM
Cavtrooper06's Avatar
Cavtrooper06
Do you key fob's look like the ones pictured at this link?
http://www.fordaccessories.com/produ...artSystem.aspx
Because these are the factory system.
Old Feb 11, 2007 | 02:16 PM
dcsmith's Avatar
dcsmith
I figured out how to work it consistently. If I push the lock button repeatedly, it will crank. While running and no key in the ignition, I press the lock button again twice to shut in off.
I don't know if that is part of the larait package or if it is after market. I works with the regular key bob, three buttons "lock", "unlock" and "panic."
Old Feb 11, 2007 | 04:15 PM
screwy's Avatar
screwy
Nope, not part of the lariat package. I'm assuming you bought it from a dealer, which is why you can't ask the previous owner.
Old Feb 11, 2007 | 05:41 PM
dcsmith's Avatar
dcsmith
Yes I did buy it from the dealer. Thanks for the comments and the interest. I know I made a big deal out of it. But, I was shocked!
Funny thing is I can shut it down with the factory key bob too; however, the stereo system keeps right on playing. The bazooka tube and its 100 watt amp plus the 200 watt amp for the other speakers would, I assume, kill the battery. I say assume because I also believe the stereo will time out. I just need not use the off function of the remote start.
Old Feb 11, 2007 | 07:32 PM
Asupreme1's Avatar
Asupreme1
It should have a remote start warning sticker under the hood.
Old Feb 12, 2007 | 06:42 AM
tweeter0108's Avatar
tweeter0108
Cool
It sounds like it is an aftermarket remotestart. This is a very common senerio, to start the truck push the lock button twice. This is done when the owner is very cheap and does not want to spend an extra $50 to have it done the right way. There are many downfalls with doing this way like the range when using the factory keyfob.
Old Feb 12, 2007 | 09:41 PM
dcsmith's Avatar
dcsmith
Maybe I should take it back to the dealer and tell them it's too cheap for me! I wanted the more expensive remote start.
theseus
Nov 11, 2017 09:31 AM
randymacbc
May 26, 2011 07:59 AM
Nite Ranger
1983 - 2012 Ranger & B-Series
May 31, 2010 12:13 AM
Doxy
Sep 14, 2009 11:57 AM
ssKable
1997 - 2003 F150
Oct 26, 2004 08:51 AM
